Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Drill mechanism locking up
Drill is stuck in place, unable to turn when trigger is pulled, and/or unable to hold a drill properly.
Chuck Issues
Could be out of place chuck jaws, or out of tolerance chuck parts, also reverse threading inside the chuck could be striped or damaged.
Hold the drill still and the chuck down. Next, gently tap using a small hammer to try and free the jaw. If that doesn’t work, insert a phillips head screwdriver into the chuck and remove the screw holding it to the drill. Then, secure the drill into a vice and attach a long allen wrench into the chuck. Using a rubber mallet hit the end of the allen wrench and the chuck should release and be easily removable. At this point, attach a new chuck, and return the previously removed screw. For more detailed instructions please see our repair guide.
Bad Wiring
The wiring is the least likely issue but if these other chcuk issues aren’t the problem, there are wiring guides to all Ridgid products or please see our repair guide.
Battery Issues
Drill battery doesn't hold a charge/charge at all.
Battery won't consistently hold a charge
If the drill battery is not holding a charge, try “deep charging” the battery by charging for a long period of time, such as overnight.
Old or malfunctioning battery
All Ridgid tools have a lifetime warranty for battery replacement as long as the tool is taken to an approved Ridgid battery service center. Simply go to Ridgid, click on the “Support” tab, then the “Service Centers” tab to locate the nearest service center.
Trigger getting stuck in the ‘on’ position
Sometimes when releasing the trigger on the drill, the motor will continue to run anyways.
Debris In Trigger
Open up the casing and remove any debris surrounding the trigger if there is any. This is most likely the issue.
Broken Mechanism
If removing debris surrounding the trigger does not work, check to see if the trigger itself is broken. It should only take about five minutes to replace the trigger. To do so please see our repair guide.
Forward/Reverse not working
Switch isn’t changing the direction of the drill.
Debris Blocking Switch
To solve this issue, simply clean around the switch. Once there is no debris in the way of the switch, test the forward/reverse functions of the drill once more.
Faulty Switch
You may need to replace the entire switch. To learn how to do so please see our repair guide.
Drill skipping or moving very slowly
When trigger is pulled drill stops and goes or hardly works at all.
Improperly Set Clutch
Check to see if the clutch is set properly. Adjust the clutch based on the numbers on the side of the drill front.
Battery Low
Remove and fully charge the battery.
4 Comments
Clutch slips all the time on a R86008 drill driver
Homer. Mchenry - Reply Share
200832003 Assy Gear Box is damaged. No replacements available.
Pawdaddy - Reply Share
Taladro y destornillador ridgid pequeño está echando humo
Rafael Sifonte - Reply Share
Taladro R82005 ridgid bota humo y tiene olor a quemado.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 47
All Time: 3,324
