Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
HTC Rezound Troubleshooting
Released November 2011, identified by model number adr6425Ivw
Poor Battery Power
Charge is not holding in the battery
Expiration of Battery
If the device is losing battery power faster then average, there may be a need to replace the old battery with a new OEM HTC Rezound Extended Battery. Search for the link [ ].
Loose Charger Jack
If the device is not holding its charge when plugged into a charger, the charger jack or the USB cable may be faulty. Charges that will hold only at certain angles or that do not charge the phone at all could mean that the charger is not fully inserted into the phone, or that the USB cable needs to be replaced.
Broken Wall Adapter
Be sure that the USB cable is not faulty or broken. If that cable is not producing a charge, it is possible that the wall adapter that it is injected into is faulty or broken. Check that the adapter is completely plugged in to the wall, and if it continues to produce no charge, it may need replacement.
Touch Screen Malfunctioning
Your touch screen is unresponsive
Broken/Damaged Screen
If the soft keys on the screen are not working or the image is flickering or the glass is cracked, search for this issue in the replacement guide for instructions on how to remove and replace the damaged glass touch screen digitizer or LCD screen. Using the tools provided in ifixit toolkit, follow along the steps instructed in the repair guide .
Overheating
Your phone is overheating or melting the battery paint
Battery Causing Overheat
The battery may need to be replaced. If necessary thermal paste may be applied when setting a new battery into the phone.
Trouble hearing phone calls
You can't hear conversations through ear speaker
Your Speaker is Not Working Properly
If there is a difficulty hearing when using the ear speaker for phone calls and voice mails, the speaker may be damaged or faulty. For this issue the most effective solution is to replace the speaker. If you click on the following link, [our repair manual will be linked here], you can follow the instructions provided in the repair manual on how to take out and replace the ear speaker.
Poor Connectivity
You are unable to connect to wifi
Your Network is Non-Responsive
If there is difficulty accessing applications such as itunes or internet searches, it is probable that the device is not connected to the proper network. Be sure that the device is connected to the correct wifi network.
Your Bluetooth Will Not Turn On
Often, when there is an issue with connecting the device to wifi, it is because the bluetooth is not turned on. Turning on the bluetooth enhances the connectivity between the device and the server.
Author
with
Bridgette Mellon
243 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 25
All Time: 509
