Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Watch Strap Falls Off
Dirt or water may have loosened band or damaged from sports activity.
Broken strap
Ensure that you have a new strap wristband at the present getting ready to be replaced, along with the tools.
  1. Pull band at base of watch
  2. Clasp is removed, clean metal on band
  3. Put new strap on (might take considerable force)
Wrong size strap
Refer to the user manual of the watch here
OR
Buy a new band and replace the current one
Powers on and off erratically
Battery may need to be adjusted or cleaned. If neither work, battery may need to be replaced.
Improper battery installation
The battery may not be in the right position or installed incorrectly which may give a bad connection. Make sure the batteries are in the right position within the socket.
  1. Open up the back of the battery by unfastening the four screws located on the back of the watch
  2. The battery is silver and about the size of a dime. Make sure that this is in the right place
  3. Twist in the four screws to resecure the back cover of the watch
Dirt in battery socket
Dirt tends to get in the watch from physical activity which may interfere with the battery.
  1. Open up the back of the battery. Do this by unscrewing the four screws on the back
  3. Use pressurized air to gently clean around the battery. Take out the battery and clean the inside well
  4. Twist in the four screws to resecure the back cover of the watch
Stopped Telling Time
The watch will stop telling time when the battery is weak.
Dead battery
  1. Unscrew all 4 screws from the back of the watch
  2. Remove the back cover
  3. Locate the battery (CR2016), Replace the old battery with the new one
MAKE SURE TO PLACE THE BATTERY FACING UP WITH THE CORRECT (+ OR -)
  1. Twist in the four screws to resecure the back cover of the watch
Eroded battery
Safely handle and discard the damaged battery.
  4. Handle the battery safely, battery could be dangerous upon contact
The second-hand skips irregularly
Second hand skipping multiple seconds at a time. It may appear as though the second hand is broken due to the erratic movements. The skipping may be due to a low battery or the motor. Preemptive measures dictate you need to replace the battery.
  1. Twist in the four screws to resecure the back cover of the watch.
Broken motor
  4. Remove the hard chip (the green part)
  5. Unscrew the motor from the watch
  6. Insert new motor
  7. Put the hard chip back on
Wrong analog time displayed
The analog arrows are displaying the wrong current time of the day.
Time needs to be set
  1. Pull back on the the crown (the twisty part on the right of the watch), the second hand will stop
  2. Freely turn the crown and adjust the arrow to the correct time
  3. Push back the crown
Crown was bumped
  2. Freely turn the crown and adjust the arrow to the correct time.
If the analog arrow still refuses to move, it's possible the crown of the watch is broken or had a malfunction inside. It is recommended to have an expert review the watch.
Sue Giske
652 Reputation
5 Guides authored
UW Tacoma, Team S1-G4, Liner Summer 2019 Member of UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Members
55 Guides authored
2 Comments
Recently, I purchased (2) Quicksilver Fifty50 Sport watches with the analogue isn’t working. The seller indicated that the analogue batteries needed to be replaced. I removed the four screws on the back of the watch, after removing the band. On the inside of the back cover there is a sticker with CR2032 and a picture of the battery in the battery holder, removed from the green circuit board. (Your trouble shooting guide for replacing the battery indicates that the battery should be replaced with CR2016. I went ahead and replaced the CR2032 batteries on both watches, with CR2032 batteries, but the analogue still doesn’t work on either watch. What’s my next step? Thank you
Ross Meinhold - Reply Share
why are you asking people who need information to answer questions?
I thought you were the pros.
Respectfully
Nicholas Parisi - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 46
All Time: 2,485
