Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet Won’t Turn On
The screen is frozen and no actions can be performed.
Battery is Not Properly Installed
Remove battery and reinstall it. A detailed guide can be found here (hyperlink to battery replacement guide). It’s possible that the battery in your tablet is not functional, in which case a new one must be purchased then installed.
Battery is Completely Drained
Plug the device into the AC adapter until the battery is fully recharged. If this doesn’t work, refer to the “Table Doesn’t Hold Charge” section.
Broken/Shattered Screen
The device was damaged and the screen is shattered, or the screen is not properly connected. Only way to fix the problem is to replace the screen.
Replace the Screen
See our guide on how to replace the screen.
Unresponsive or Jammed Buttons
Expected action is not performed when a button (e.g. power or volume) is pressed.
Soft Reset the Device
Open up the applications menu by tapping the icon with 6 white squares, which is located in the bottom center of the home screen. Tap the settings icon, then scroll down to "Backup & reset". Next, select "Factory data reset" under the personal data subcategory, then "Reset tablet" and "Erase everything".
Fix a Jammed Button
Turn off the device, then open the rear case with a plastic pry tool to check if the button is being jammed by anything. If it is, clear any obstructions out of the way. Snap the case back onto the tablet, turn the device on, and check if the button is working again.
Tablet Doesn’t Hold Charge
Device only works when device is plugged in or holds charge for only a short period of time.
Drained/Bad Battery
Plug device into AC adapter. If it does not charge, the battery most likely has gone bad. In this case you need to replace the battery, following our guide’s steps (follow link).
Broken AC Adapter
Plugging the device into the AC adapter doesn't replenish battery life.
Replace AC Adapter
If AC adapter is broken, you can simply buy a new one. Alternatively, if only the micro-USB power cable is not functional, it can be replaced with any other micro-USB cable.
Author
with
Matheus Silva
4 Reputation
0 Guides authored
USF Tampa, Team 1-5, Tanski Winter 2015 Member of USF Tampa, Team 1-5, Tanski Winter 2015
USFT-TANSKI-W15S1G5
3 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,134
