Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Drone Does Not Lift Off
The drone does not take flight when prompted.
Propellers may be in wrong slots
There are rear and front sets of propellers. If the propellers are put into the wrong part, i.e the rear are placed in the front or vice versa, then they will not allow the device to take off. Check the markings on propellers and make sure they are in right place which may be indicated in manual.
Battery may not be fully charged
Make sure the battery is charged according to the instruction manual. If the battery is fully charged and the drone is still not lifting, replace the battery.
Drone is not turned on
Make sure power switch is turned to ON.
If lights turn on but do not flash, make sure there are no devices synced to the drone.
Can't connect to drone WiFi
Cannot connect phone to drone over its WiFi signal.
WiFi network is not emitted
If your phone is unable to see the Dronium III WiFi, you may need to turn the drone off for one to two minutes and turn it back on. Also close the WiFi tab in your phone and re open it. Then select the Dronium III WiFi when it pops up.
Ensure the drone power switch is set to ON, and all lights are flashing.
Connection is lost
If WiFi connection between the drone and your cellular device is lost, you may need to reconnect to the WiFi. If so, enter your WiFi settings in your phone, and select the Dronium III WiFi. If it is not found, revert to the "WiFi network is not emitted" portion of the guide.
Controls Not Working
Controls on remote do not make drone work.
Device is not connected to controller
To sync controller to the drone
* Turn on the Dronium III.
  • Turn on the controller.
  • Ensure there are no other controllers synced to the drone.
  • Move the Throttle Control stick on the controller to the forward position, then immediately to the back position.
  • Release the Throttle Control stick so that it returns to the center position.
The controller will make a beep sound and the lights will turn solid when sync'ed.
Blades Do Not Spin
The blades do not turn and bring drone into sky.
White toothed housing is out of line of Piston
Unscrew the cap over the rotor in the bottom of the wing (there are four motors, so four caps). There is a little piston that fits into a white toothed housing that spins and turns the bigger wheel. This little white housing may be slightly off the piston so take a screwdriver and push it down back onto the piston.
Drone won't power up
Drone is unresponsive and does not turn on or power up.
Power switch is not turned on
Make sure the power switch is turned to ON.
Battery pack is not connected
If battery pack is not connected or is poorly connected the device will not turn on.
To ensure batter pack is connected
  • Open Dronium III battery compartment.
  • Remove and unplug battery if installed. (If battery pack is not installed skip this step.)
  • Ensure the connection is tight and secure.
  • Insert battery pack into the battery compartment.
  • Close battery compartment.
Author
with
Preston Ashley
101 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 2,142
