Camera Will Not Turn On
Remember to hold down the power button for more than three seconds to turn camera on.
Batteries
If your camera is still not turning on there may be an issue with the batteries. Some possible problems could be:
  • The batteries may be missing.
  • The batteries may be inserted in the wrong direction.
  • Or, the batteries may be dead.
If you have one of these problems, please follow the link to our [battery replacement] guide.
Power Button
The power button may have been damaged as well. If this is the problem, please follow this link to our [Button Replacement] guide.
Screen
If you feel the camera is turning on, but the screen is not working, please follow the link to our [LCD replacement] guide.
Button Malfunction
The Button set to the side of the LCD Screen may be damaged during use. These buttons control zooming, and menu options:
  • Zooming buttons do not work.
  • Cannot view photos.
  • Cannot access menu.
  • Cannot change display settings.
  • Directional buttons do not work.
  • Cannot delete photos.
  • Scene selection menu not accessible.
  • Buttons are water damaged.
If you encounter any of these problems please follow the link to our [button replacement] guide
Shutter Button
If the camera is not taking pictures, but is on, there may be a problem with the shutter button. If you feel this may be the problem, please follow the link to the [button replacement] guide
Zoom Lens Malfunction
If there is a problem with the zoom lens, it may need to be replaced. To replace the zoom lens, follow the link to our [zoom lens replacement] guide.
LCD Screen Display
If the LCD Display is having any of the following problems:
  • LCD is cracked.
  • LCD has sustained water damage.
  • LCD has a poor connection.
  • LCD no longer works and needs replacement.
follow this link to our [LCD replacement] guide
Flash Problems
  • Flash has sustained water damage.
  • Flash has a poor connection.
  • Flash casing is cracked or missing.
  • Flash tube/bulb is dead or broken.
If you suspect you have any of these problems, please follow the link to our [flash replacement] guide.
Outer Case Broken
The case encloses all functioning parts of the camera. Some problems with the case include:
  • Cracked Case.
  • Scratched Case.
  • Battery flap does not close.
If you are having one of these problems, please follow the link to our [outer case replacement] guide.
Aric Champagne
18 Reputation
1 Guide authored
Cal Poly, Team 3-4, Johann Summer 2010 Member of Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 Members
48 Guides authored
3 Comments
Do I need the SDHC Memory card for the LCD screen to show an image?
Yvonne Luckett - Reply Share
I have a Polaroid iE4038, 18MP/Optical 40x camera which I have never really used - bought it new online a few months ago - it has new batteries, but the LCD screen just gets colored green lines all over it….it will not show an image…..do I need the SCHC Memory card for the LCD screen to work, or is there just something wrong with this camera? Any advice would be greatly appreciated. TYIA
just got a polaroid i534 camera it turned on fine but after awhile it turned off and i saw some smoke coming out the battery socket (it works on AA batteries) and now it wont turn back on what do i do i paid for this with my own money and i’d be damned if this thing doesn’t turn on
Shifa Haque - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 45
All Time: 8,265
