The Polaroid Sun 600 LMS can be identified by the labeling on the front face.
Note: This troubleshooting guide covers the Polaroid Sun 600 LMS. Any other Polaroid Camera will be covered in a separate troubleshooting guide.
The camera will not flash
When a picture is taken there is no flash.
Battery issues
The battery is either dead or there is no film pack in the camera. The film pack has the battery built into it. Install a fresh film pack and try again.
Surrounding light
There may be too much light for the light sensitivity switch, so the camera will not flash. Go to a darker place if flash is necessary.
The camera stops working mid-film pack
After the last shot, the camera stopped working.
Dead battery
The battery could be dead. Try installing a new film pack because the battery is located in the film pack.
Poor battery contacts
If the film pack has been removed since the previous shot, the battery contacts could have been bent or pushed back into the camera and are not touching the battery terminals. See repair page on bending of terminal contacts.
Gear train failure
The internal camera gears may be hung up on something and need to be turned manually to get it working. See repair page for advancing gear train manually.
Pictures are discolored
The pictures are not turning out they way they should.
Light sensitivity switch
If the pictures seem washed out or overexposed, try lowering the light exposure setting on the camera. See light sensitivity switch manipulation.
Bad film pack
The film pack is damaged from exposure to radiation. Installing a film pack will fix this problem. See installing a film pack.
Ian Hosek
365 Reputation
1 Guide authored
Cal Poly, Team 3-18, Maness Winter 2010 Member of Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Members
48 Guides authored
1 Comment
my camera is charging the flash but it won't take pictures or eject the dark cover
Aarenas3 - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 75
All Time: 22,548
