Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Picture Will Not Print
Even after taking multiple photos, your Polaroid SNAP will not print.
Paper Jam
If you have taken a photo and the light is flashing red, you may have a paper jam. Possible reasons why there is a jam could be: more than ten sheets of paper, bent paper, and backwards paper. To fix the jam, remove the paper carefully with out damaging the camera and insert new sheets making sure they are oriented correctly and do not exceed more than ten sheets.
No Paper
If you have taken a picture and nothing immediately prints, open the paper door. Check to make sure there is no paper in the door and confirm that the paper status LED is flashing red. If you confirm there is no paper, insert new sheets making sure they are oriented correctly and do not exceed more than ten sheets.
Low Battery
If the picture will not print, and you checked the above symptoms, you may have a low battery. Check to see if the Battery LED is flashing red or is not on at all (note: a white LED indicates that the camera has a sufficient battery level.) If this is the issue, attach the charging cable and let charge until LED is white.
Wrong Type of Paper
If an image does not print after immediately taking a picture and you have confirmed it is not one of the above symptoms, you may have the wrong paper. Replace the incorrect paper with ZINK paper making sure they are oriented correctly and do not exceed more than ten sheets. This may solve the issue.
Flash Does Not Operate
The lighting in your pictures is off, and the camera flash does not seem to work properly.
Flash Obstruction
Make sure to check that there is nothing blocking the flash on the front left side of the camera. The flash is small and in an area where your hand is while taking a picture, so a finger blocking it is common.
Low Battery
If the flash is not coming on at all, check the battery LED on the back of the camera and see if it is red and/or flashing. If it is, plug charger in and allow camera to gain sufficient charge before trying again.
Internal Damage
If the camera has battery life and the flash is not working, there may be internal damage . The camera has an auto flash feature and should work at all times. If the device has not suffered water, heat, or physical damage, then it may be defective, requiring you to contact the company directly.
Camera Will Not Take Pictures
After multiple attempts, your camera will not take pictures.
Lens Cap
Before trying to rip apart the device, make sure you check the simple causes that could prevent you from taking pictures. Check to make sure that the lens cap is off. If it is not off it will not work.
Drained/Bad Battery
If your Polaroid SNAP will not take pictures, you may simply have a drained battery. Just connect the SNAP to the power cable and let it fully charge.
Auto Sleep
If you have left your Polaroid SNAP on and after several minutes you try to take pictures and it does not take the picture. Your SNAP might have just simply gone into auto sleep. To use it again just close and re-open the viewfinder, and it should be working perfectly fine after that.
Camera Will Not Turn On
After multiple attempts, your device will not turn on.
Battery Issues
If your camera will not turn on, your battery could be dead. Connect the SNAP to the power cable and let charge until a white LED appears. If a red LED does not flash while the SNAP is charging, then the battery might need to be replaced.
Broken View Finder
When you press on the view finder it should pop up. If it does not pop up, this could be a reason why your device won't power on. A small lever triggers the power for the device as the viewfinder rises.
Internal Damage
If you checked the battery and your view finder is functioning, your device could have suffered internal damage. If the device has not suffered water, heat, or physical damage, then it may be defective, requiring you to contact the company directly.
Camera Freezes After Taking a Photo
After taking a few photos and having the camera work properly, it suddenly freezes up and I cannot make it work.
Drained/Bad Battery
If your Polaroid SNAP suddenly will not take pictures. it may have died when you tried to take a picture and you may simply have a drained battery. Just connect the SNAP to the power cable and let it fully charge.
Auto Sleep
Paper Jam
Firmware is Out of Date
The camera may be freezing up and just generally not operating in a proper manner, this may be due to out of date firmware. To update the firmware on your camera, ensure that you have an SD card in the camera and connect your camera to your computer via the charging cable. Then download the proper firmware files from the official Polaroid website and save them onto the SD card. Proceed to unplug the camera from the computer and turn it off and then back on, after which the status LED's will turn red for 30 seconds. If a sounds plays after this time period, then you have successfully updated the firmware for your device.
Author
with
Ian Colantuoni
643 Reputation
2 Guides authored
USF Tampa, Team 7-3, Cheng Spring 2016 Member of USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Members
72 Guides authored
309 Comments
Hello everyone and thanks for this troubleshoot page.
Unfortunately i'm encountering a problem with my SNAP that is not listed here.
The camera works well, but in every photo it prints there is a blue line in the lower part of the photo.
The line is ALWAYS in the same part. I Can't understand if is a Paper problem or a Camera problem, and right now I don't have any other kind of paper (i'm using the ZINK paper, not the premium one) in order to do some tests.
Anyone has encountered this kind of issue?
Regards
Mirco
mirco0806 - Reply Share
Same problem, have you found a fix?
Martin Masotta - Reply Share
Not yet, even updating the firmware. Actually still having the issue, expecially if using non-premium paper.
Mine isn't damaged and after every picture they print out with lines running threw the entire picture
odiz93 - Reply Share
Has anyone found out why these blue lines are on their pictures? And what to do about them?
I heard cleaning the printer may help but have not found anything on how to clean the printer?
crave.u - Reply Share
Past 24 Hours: 15
Past 7 Days: 110
Past 30 Days: 404
All Time: 348,690
