Camera Will Not Turn On
Dead Battery
If the camera does not turn on, the problem may be that the battery is dead and needs to be replaced. The cartridge holding the undeveloped film and power pack are the same unit. After replacing the cartridge, the camera should turn on.
Guide to Replace Battery
Camera Will Not Take Pictures
Out of Film
If you are trying to take pictures, but the camera will not shoot, the camera may be out of film. All you need to do is replace the cartridge. Once the cartridge is replaced, try turning the camera on and taking a picture.
Repair Guide to Replace Film
The Flash Will not Go Off
Bad Connection Between the Bulb and Camera
If the flash will not go off while taking a picture, there may be a bad connection between the camera and flash. The wires may have been severed and will need to be checked out.
The Bulb is Burned Out
If the flash still will not go off after the connection has been checked out, the bulb may have burned out. You may need to replace your Polaroid camera.
Back to the Device Page
Author
with
Doug Jimenez
556 Reputation
2 Guides authored
Cal Poly, Team 16-31, Maness Winter 2010 Member of Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Members
48 Guides authored
28 Comments
I will put the film into my camera and it will make a loud kind of "rrrrr" and the top rolly thing (sorry if you need a more detailed description ask) keeps spinning until I take out the film. This camera was my great grandpas before he recently passed and I want to use it like he did.
Please help.
Mary Gray - Reply Share
I received a polaroid 600 for Christmas and I have just tried to use it andoes it has done the same thing .. I took one picture and it spat out all 8 and the roller won't stop going until we take the photo try out .. hope we get some help
Liane Spiller - Reply Share
I have the exact same problem here! Help!
Mon - Reply Share
I have the exact problem!!! Did you find out how to fix it after all???
ilka21792 - Reply Share
I've been using a spirit 600 for a few months and it's been working great. All of a sudden it's stopped ejecting pictures. I've lost two packs of film so far to this :( any help is appreciated.
Michele B. - Reply Share
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 255
All Time: 80,428
