Controllers will not connect to PlayStation
The controllers have power but the PlayStation is not recognizing them.
IR Sensor
The IR Sensor reads the signal sent by the controller, allowing the user to control the game wirelessly. If your IR Sensor is not working, you must replace it.
PlayStation will not turn on, or the screen flickers during gameplay
''The power and video cables are plugged in properly, but the device does not turn on when you turn on the power switch.’’
Motherboard
The motherboard is the brain of the PlayStation. If the device is plugged in but does not respond, the motherboard is typically the source of the problem.
System overheating
You can feel excessive heat coming from your PlayStation, and your games freeze during gameplay.
Fan
The components inside the PlayStation generate heat as you play, and the fan is designed to exhaust heat from the console. If your system is overheating, you may need to replace the fan. If the fan operates when the Playstation is on but dust has accumulated around the fan, you may need to clean the inside of your system with a can of compressed air.
“Disc Read Error” message or disc drive does not open
When you insert a disc you see a 'Disc Read Error' message on the screen, or the disc drive does not open when you press the eject button.
Damaged Disc
Check the disc for deep scratches that may prevent the PlayStation from reading the game.
Optical Drive
If the disc is not scratched, but the PlayStation still will not read it or the drive will not open, you may need to replace the optical drive.
PlayStation clock resets every time the system is powered on
Clock Battery
When the PlayStation is powered off, time isn’t stored on the device and the clock displays a random time when powered back on. Replacing the clock battery will solve this problem.
Author
with
Thomas Sullivan
4,876 Reputation
6 Guides authored
4 Comments
ps2the disc does not spendis it the spindal motoror is it the lazor is there way to test them…
steven - Reply Share
Hello my ps2 slim acts erratically, mostly does not load any disks, then from time to time it does load the disk but it takes forever to go through menus and to game play, where at that point, gameplay, it hangs. What can the issue be related to ?
paolo abenavoli - Reply Share
Help the little blue pieces on my ribbon cable for the power button came off its a ps2 slim
Ps2 gamer - Reply Share
when we sent the ps2 slim to repair and he said that he had disconnected the reader and that it could be changed or use the usb ports, which is what we decided to do. but time after it stopped working and gave us disc reading error
ztv1hmjpd@mozmail.com - Reply Share
Past 24 Hours: 9
Past 7 Days: 40
Past 30 Days: 131
All Time: 6,365
