Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Radio Will Not Turn On
The radio does not power up.
Ignition Not In "ACC" Position Or Motor Not On
After putting the key in the ignition, to it to the "ACC". Turning the key to the "ACC" position will send power to the radio and power it on. Also, starting the motor on the vehicle will allow the radio to power on.
Power Button Pressed
Hold down the power button on the radio for a few seconds. After doing so, the screen will turn on, and go back to normal.
Blown Fuse
Once locating the fuse on the back of the head unit, pull the fuse out and check to see if the arch in the colored plastic is connected. If not, the fuse is "blown" and needs to be replaced. Replace fuse with the same amp rating and radio will power on.
Recent Dead Car Battery Change
If the car battery died while you were operating the radio, it could have sent the radio into an anti-theft mode. To reset the radio, you need to consult the manual. Within the manual, there is a code to turn off anti-theft mode.
Pioneer MXT-X386BT and MXT-X186UI Owner's Manual
Sound Cutting Out Over Bumps
The sound cuts off as the vehicle travels over bumps.
Main Power Cable Loose
Check the main power cable to the battery. Wiggle the power cable connected to the battery, by touching the plastic casing around the wire, to see if it is loose. A loose battery cable can cause intermittent power loss to the radio. Tighten the clamp connecting the cable to the battery.
Loose Contact WIth Head Unit Wiring Harness
Locate the white wiring harness on the back of the head unit. Wiggle the harness to check if it is loose. If loose, firmly push the harness back into the head unit. If it does not connect, you will need to replace the wiring harness.
Loose Ground Wire
Locate the ground wire leaving the radio. The ground wire will be connected to bare metal on the vehicle. Tighten the ground wire to the vehicle to ensure it is making contact.
Speaker Wires Not Connected Tightly
Locate the wires that lead to each speaker that comes from the wiring harness. Check to see if the connections between the wiring harness and the vehicle's speaker wires are connected tightly. If not connected tightly, replace the wire connectors to ensure a solid connection.
Power on but no Sound
The radio has power but no sound is being produced.
Volume Turned Down
Turn the volume knob, located on the left of the face plate, to the right to turn the volume up.
Bluetooth Not Connected
Check to ensure that the Bluetooth has been paired correctly with the head unit if you are using a Bluetooth connection. Scroll through the connection settings and find "Connect Bluetooth" and follow the instructions given by the radio.
Screen And Sound Cutting Off
The sound and screen are both cutting off intermittently.
Faulty Battery
Having an old battery or a faulty battery could cause the radio to not have enough power. The battery to your car may need to be replaced.
Face Plate Not Inserted Correctly
The face plate on the head unit may be loose or not connected all the way. Push the face plate back into position firmly to ensure that it is properly secured.
Head Unit Wiring Harness Loose
Sound Not Being Produced By Every Speaker
Sound is not being emitted from every speaker in the vehicles sound system.
Configuration Setting
The settings on the stereo may be set up in a manner that only provides sound to one side/bank of speakers. Check the settings in the head unit by cycling through the menus and make sure that the stereo is configured in a manner that provides sounds from all sides.
martin esquivel
329 Reputation
2 Guides authored
18 Comments
my avh-110bt turn it to radio but cant turn it no radio station no;
Scott Rogers - Reply Share
What if the radio cum on everything work but sound what do I do ??
Roshonda - Reply Share
Touch screen not working when touched
Roman gemini - Reply Share
Touch screen does not work when touched
I dont have the manual to see my code. What can i do
Joseph Naddaf - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 69
All Time: 62,911
