Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Toothbrush won’t turn on
You can’t get your toothbrush to turn on.
Press the power button
The top button is the power button and the bottom one changes the mode. The mode button will not turn the toothbrush on so be sure that you are pressing the correct button. If your toothbrush still won’t turn on, keep reading.
Drained/Bad battery
You may just have a drained battery. Put your toothbrush on the charger and ideally the LED lights will turn on, showing that it is charging. If it will no longer charge, the battery must be replaced with a new one. Use this Battery Replacement guide.
Toothbrush making too much noise
The toothbrush makes much more noise that it did when it was new.
Loose actuator screw
Most likely the actuator screw is loose and must be tightened. Use this guide...
Toothbrush turns on but the head doesn’t move
You can hear the toothbrush making a humming sound but the brush head doesn’t move.
Broken shaft
The shaft that connects to the toothbrush head may be broken. It will need to be replaced. Use this Shaft Replacement guide.
Toothbrush is not charging
The toothbrush cannot charge.
Charger not properly plugged in
Check to see if the charger is properly plugged into an outlet, and check to see if the outlet gives any charge.
Charger may be broken
If the charger cannot charge any toothbrush, then the charger itself may be faulty. Check to see if the charger is working by placing your toothbrush on the charger. If the battery light on the toothbrush doesn't light up, charger will need to be replaced. Use this guide ...
Broken battery
If the charger works fine, the battery on the toothbrush may be broken and will need to be replaced. Use this Battery Replacement guide.
UV Cleaner not turning on
The UV cleaner provided with the toothbrush does not turn on.
Cleaner not properly plugged in
Broken UV bulb
If the outlet works fine, the UV bulb in the cleaner may be broken. Fortunately, the bulb can be easily replaced. Use this UV Light Bulb Replacement guide.
Alex Renee
1 Reputation
0 Guides authored
47 Comments
My uv works but the toothbrush charger only makes sounds when I put the toothbrush handle on it. But the charging light never lights up and the toothbrush doesn't turn on.
julie dozier - Reply Share
Mine too : /
Branden Griffith - Reply Share
My new diamond clean brush has been charging for well over 24hrs and is still flashing a green light (slowly) Is this normal? I was expecting a solid green light about six hours ago.
Matthew Smith - Reply Share
Mine still lights up but won't turn on and when it's on the charger the lights light up and u can hear it charging. It randomly turns on by itself but will not turn on when I try to turn it on. It just turns on and off by itself. What can b wrong with it?
wanetta - Reply Share
Did someone from Philips respond and explain what is happening with your sonicare? I am experiencing the same situation.
Thanks in advance for any feedback you might be able to provide.
Doug - Reply Share
Past 24 Hours: 6
Past 7 Days: 82
Past 30 Days: 277
All Time: 253,859
