Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Oster Simple Blend 100 Troubleshooting
This troubleshooting page will help you diagnose problems with the Oster Simple Blend 100.
The Blades Will Not Turn
The blades won’t turn properly while being used.
The Jar is Not Attached Properly
While the blender is unplugged, make sure that the jar is attached properly onto the base of the unit.
The Blade Assembly is Loose
While the blender is unplugged, take apart your blender until you have access to the blade’s assembly. Make sure that everything is in place with the O ring over on top of the agitator and placed into the base, which will be screwed onto the jar tightly.
Food is Stuck in the Blades
While the blender is unplugged, check the blade assembly for any food that has jammed the blades and remove it carefully.
The Motor is Damaged
If the blender does not work after checking all the previous symptoms, then the motor may be damaged. Purchase a new motor to replace the damaged motor.
Motor Does Not Work
The motor will not work properly while being used.
The Motor is Overheating Quickly
The blender’s fan may be broken. A new fan for the blender will need to be purchased to replace the damaged fan.
If the blender does not work after checking the previous symptoms, then the motor may be damaged. Purchase a new motor to replace the damaged motor.
Smell of Smoke or Burnt Plastic
The blender gives off a smell of smoke or burnt plastic while being used.
There is Not Enough Liquid
If there is not enough liquid in the blender jar while in use, its content can rapidly scrape the sides and give off the smell of burnt plastic. Make sure to use at least enough liquid to cover the blender’s blades.
The Blender is Being Overused
Being that this is a very simple blender, it is not made to be used for more than 10 seconds at a time. Use it for 10 seconds at a time, giving it 10 seconds of rest between blends.
Blender is Leaking
The contents of the blender jar leak out.
The Lid is Not the Right Size for the Blender
The blender may leak through the top of the blender if the lid is not the right size for the blender. Check the Oster website to make sure that your lid is the right size for your blender jar, and if a replacement is needed check the Oster website.
Blender Jar is Cracked
If the blender jar is cracked, its contents will most likely leak out of the side. Check the Oster website to replace this part.
O Ring is Not Secured
 If the O ring on the bottom of the blender jar is not secured, it may leak out of the bottom of the blender. Make sure the O ring is secure and use the blender to make sure that is the fix needed.
Rim broke
The plastic rim broke while being used
Big Chunk of Frozen Fruits/Ice Cubes Being Used at Once
If there are many frozen fruits or ice cubes being used at once, it could cause the rim to break throughout the process of blending. Try to reduce the amount of frozen fruits or ice cubes and add more water into the blender.
On button and/or other button(s) doesn’t work
The button won’t function when its plug in
Too Much Pressure When Button is Pressed
If pressing repeatedly on the buttons, the buttons would potentially be disconnected with the blender and cause problems. Try to press it once and wait for it to work.
Outlet Does Not Work
Often, some outlet/plug would not work because it does not have enough power for the blender. Try to place the blender in a different area with a different outlet and check if it is working. Replace the blender if it is still not functioning.
Kristen Gismondi
110,412 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 41
All Time: 2,039
