Optical Drive has trouble loading discs
If the player is having trouble loading or reading discs, the problem is almost always mechanical. Try these quick tricks:
1) nudge / slide the laser assembly back and forth in its track, using your finger or some sort of plastic tool like a spudger or a pen cap*
2) clean the laser lens (with 90% isopropyl alcohol and a q-tip)**
Our experience at Fixit Clinic is that the vast majority of optical disc drives will spring back to life after step 1) and/or step 2) above. If neither of those works:
3) confirm that there isn't foreign matter like hair wrapped around the motor spindle or a dust bunny in the CD tray slot or mechanism.
If 1) the laser assembly is moving OK, 2) the motor is spinning freely and 3) you're sure there's no foreign matter in the drive THEN perhaps the laser has stopped working: try removing and reseating the ribbon cable to the laser assembly. If that doesn't work then the laser might have burnt out. (Depending on the design of the optical drive you might be able to use a transparent disc (you get one or two of these when you buy a stack of discs) to see if the laser is indeed lasing.) A burnt-out laser is a hard repair because you have to identify and replace the part.
If you try nudging the laser a few times unsuccessfully as in 1) above, notice where you left it last time and see if it moves in its track at all when you try the next time. If not, it's possible that the ribbon cable to the laser assembly came loose or needs to be reseated. (You should also hear noise as the laser assembly moves back and forth trying to find the beginning of the disc.)
Confirm that the (tiny!) plastic lens is indeed still on the laser assembly: we've seen one optical drive where the lens popped loose and was rattling around in the case: gluing it back fixed the optical drive.
If you open the case: It's always worth it to visually inspect any capacitors to see if they're bulging at the top: they could keep the laser from working even if everything else seems to be OK.
TRAY DOOR HINT
Console-style players usually have a plastic cosmetic trim piece on the front of the tray door slot that needs to be removed to get full access to the drive. it usually comes off by pushing it up, but it _might_ be secured with screws.
DISC PROBLEMS
If the problem is reading a specific disc e.g. freezing or stuttering (like with heavily used discs borrowed from the library): lightly polish any scratches on the disc with an abrasive toothpaste (like Colgate or Crest) or with a paste car wax: emphasize radial strokes in your buffing, i.e. going from the center to the edge and vice-versa. If a specific disk won't read at all: look for heavy scratches towards the center and emphasize polishing those (optical discs read from the center out, and the laser can't find track 0 to start reading the disc.)
Fixit Clinic
786 Reputation
2 Guides authored
Global Fixers Member of Global Fixers
Community
68 Members
3,039 Guides authored
3 Comments
hi - for those of us who have no idea what these parts are or how we might pry them off? where do we go? really, i can guess what a “motor spindle” might be but i’m clueless.
Cassandra23 - Reply Share
Too technical to be of any use.
Bob Carr - Reply Share
These things are SO delicate, 99% of people have no business taking off the cover. I'm not trying to be Arrogant, it's just the way they are. Almost everybody who trys, will take a machine that could have been repaired, and make it irrepairable. Just static electricity will kill them. So if you think you might have the skill, do it in the summer, or buy and use a anti-static strap that goes from ground to your wrist. Good luck The tips here are good.
Sara Heart - Reply Share
Past 24 Hours: 15
Past 7 Days: 103
Past 30 Days: 427
All Time: 18,307
