Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Screen is unresponsive
The phone’s touch screen may stop working after upgrading the software in the phone. You may also experience green or red lines coming down vertically across the screen, with this your touch screen may not work as well. To avoid some of these you can do the following to help.
The Phone needs to be Restarted
A system restart on your phone to get rid of the lines and to get the touch screen working. A screen replacement on the phone can also solve some of the problems.  You are also able to connect a controller to be able to use the phone if the touch screen is non-operating. Also keeping the brightness down to avoid it from burning out.
The Phone needs a Software Update
Outdated software can sometimes cause display issues due to bugs or compatibility problems. Check for system updates by going to Settings > System > System updates. Installing the latest software version can address known issues with the display.
The Phone needs to be Factory Reset
If the screen issue seems to be software-related and persists despite updates, consider performing a factory reset. This will erase all data on your device, so back up important files first. To reset, go to Settings > System > Reset options > Erase all data (factory reset). Follow the prompts to complete the process.
The Screen is Damaged
Inspect your device for any signs of physical damage. Drops, impacts, or pressure can damage the screen, leading to distortion or burn-in effects. If you find physical damage, the screen may need to be replaced.
Phone Wont Turn On
One Plus Nord N200 won't power on and does not respond to the touch or any buttons.
The Phone is Not charged
Though the Nord N200 has a long battery life, it won't live forever! The phone comes with a USB-C battery charger, but if yours has any issues, any micro USB-C charger should work. Plug in your One Plus Nord; the Nord should charge fully in about 75 minutes according to One Plus.
The Charger is Defective
The problem may not be with the One Plus Nord, and instead be a problem with the charging cord itself. Try charging a familiar device with the same charging cord you used with the Nord to verify that it functions properly. If the cord cannot charge your other device, it is most likely faulty and a new one should be purchased. Charger(s) can be found at any major selling corporation. Or replacing the entire charging port can be an option, you can follow the following video to guide you through the process.
The Battery is Faulty/worn-out
If the device still won’t power on, the problem may lie in the eternal battery. The battery is not getting power, which could be caused by a few reasons, the main ones being an improper connection to the battery terminal or a faulty battery. This would require opening up the phone and replacing the battery.
The Motherboard is Faulty
At this point if the device still won't power on, the problem may lie in the heart of the device; the motherboard. The issue could be due to many reasons, such as a faulty motherboard, bad connections, A short circuit in the motherboard preventing power. This issue is a more advanced fix requiring soldering and reworking the device circuit components or replacing the motherboard and reconnecting the components to the motherboard.
Phone audio recording doesn't sound clear
The One Plus Nord N200 may have poor audio recording, with muffled, crackling, and distorted audio and sound quality in videos.
The phone is on Low-volume
An issue with the One Plus Nord N200 is its low volume output, which may affect the overall user experience. Users have noted that the speaker volume for media playback, ring tones, and alarm tones may not be as loud as expected, potentially making it difficult to hear audio clearly in noisy environments or even in typical indoor settings. This issue could also impact the clarity and volume of calls on speakerphone.
How to Replace Speaker
The Phone needs Software Updates
Outdated software can sometimes lead to issues with audio recording due to bugs or glitches in the system. Navigate to Settings > System > System updates on your device to check for any available updates. Installing the latest software version can often resolve audio issues.
The Audio Settings need to be optimized
Customized audio settings might interfere with the recording quality. Resetting the audio settings to their default can help. Go to Settings > Sound & vibration and look for an option to reset the sound settings. This action will not delete personal data, but it will revert all sound settings back to their original state.
Third-Party Apps Interference
Some third-party apps can interfere with the microphone functionality. If the distorted audio recordings are happening within a specific app, try uninstalling and reinstalling the app. Also, test the microphone using the built-in voice recorder or camera app to determine if the issue persists across different applications.
The Phone has a Microphone Blockage
The most common cause of poor audio quality during recordings is blockage of the microphone. The OnePlus Nord N200 uses multiple microphones for noise cancellation and audio recording. Ensure that none of the microphones are blocked by lint, dust, or debris. Use a flashlight to inspect the small microphone holes around the device, especially near the charging port and along the edges. Gently clean any visible blockage with a small, soft-bristled brush or a burst of compressed air.
The Microphone is Faulty
If you have tried all the above steps and the audio recording is still bad or distorted, the problem might be related to a hardware issue with the microphone itself. This could be due to water damage, physical damage, or wear and tear over time. The speaker or microphone may need to be replaced.
Camera quality is not clear
When trying to take a photo the camera quality is blurry and very bad quality or nothing shows up on the camera screen just a black screen.
Check Camera App Permissions
Ensure that the camera app has the necessary permissions to function correctly. Go to Settings > Apps & notifications > See all apps > Camera > Permissions and verify that the camera app has permission to access the camera hardware.
The Camera App and System Software needs to be Updated
Outdated software can lead to performance issues. Check for updates for both the camera app in the Google Play Store and your device's system software under Settings > System > System updates. Installing the latest updates can resolve known bugs affecting camera functionality.
The Camera is Physically Obstructed
This is an easily diagnosable issue. If the camera is very low quality or just a black screen when the camera app is open. It could be anything from a smudge on the lens, a cracked lens or If you've recently applied a new case or a camera lens protector to your OnePlus Nord N200, make sure it's not obstructing the camera lens or flash. Some poorly designed accessories can block the camera or degrade photo quality. If you notice any black spots on your screen when using the camera, double-check that it is not an issue with your screen first.
The Camera lens is Faulty
After ensuring that it is indeed your camera. It could appear as a black spot, a blurry white line across your screen. Most of these issues you will be able to tell whether it is something on the actual camera lens or if it is an internal issue. You can use this video to learn how to replace your smartphone's camera lens. If the entire camera system is not working properly, click here so you can replace the camera system yourself.
Can't hear anything when headphones are plugged in
The headphone jack on the OnePlus Nord N200 is not functioning properly, preventing audio from being heard through connected headphones.
Headphones Are Not Fully Inserted
The most common issue is that the headphones may not be fully inserted into the headphone jack. Ensure that the headphones are pushed in all the way until you hear a clicking sound. If the headphones are not fully inserted, the device may not detect them, resulting in no audio being played through them.
The Headphones are faulty
The problem may not be with the OnePlus Nord N200 but with the headphones themselves. Test the headphones with another device to ensure they are working properly. If the headphones do not work with other devices, they are likely defective and need to be replaced.
The Audio Settings are Misconfigured
Check the audio settings on your OnePlus Nord N200. Ensure that the audio is not being sent to a Bluetooth device instead of the headphones. Go to Settings > Sound & vibration and make sure the media audio is set to play through the wired headphones when they are connected.
There is Lint or Debris in the Headphone Jack
Over time, lint, dust, or other debris can accumulate inside the headphone jack, preventing a good connection between the headphones and the phone. Use a flashlight to check if there is any visible debris inside the headphone jack. If so, gently remove it with a toothpick or a small needle. Be careful not to damage the interior of the jack.
The Headphone Jack is Damaged
If none of the above solutions work, the headphone jack itself may be damaged. This could be due to dropping the phone, liquid damage, or wear and tear over time. In such cases, the headphone jack may need to be professionally repaired or replaced. You can follow an online guide or video tutorial to replace the jack yourself if you are comfortable with device repair.
Author
with
Fabrise Niyonkuru
1,138 Reputation
9 Guides authored
UMass Dartmouth, Team 1-1, Konn Spring 2024 Member of UMass Dartmouth, Team 1-1, Konn Spring 2024
UMASSD-KONN-S24S1G1
4 Members
108 Guides authored
1 Comment
How do you get out of recovery mode? Not sure how it got there to begin with.
Len - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 57
All Time: 1,471
