Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Onda VI10 will not turn on
When the power button is pushed the tablet does not power on.
Faulty power adapter
Check to make sure the outlets is working, plug in the adapter, if tablet still do
not power on then you might consider replacing the charging adapter.
Faulty power button
Carefully remove the four screws that hold the back casing and check to make sure
your power button is not sticking or is not making contact with
the powering switch that is connected to the circuit board.
If the home button needs to be replaced, view this guide.
The tablet will not power on
Onda VI10 has broken screen
Onda VI10 has a damaged screen
Check if the tablet powers on
Remove any screen protectors to reveal full extent of damage
- If screen is cracked, refer to the replacement guide here.
Audio is distorted
Onda VI10 speaker does not produce sound
Make sure volume is turned on
Play anything with sound, if still not working, you may consider replacing the speaker
- Refer to this guide on how to purchase and replace the speaker
Buttons are sticking
Buttons on the Onda VI10 are sticking or unresponsive or dislodged
Check for any debris that may be caught in between buttons
1. If possible remove debris with toothpick
2. If buttons are still stuck, use an Air Duster can to blow out the buttons.
3. If buttons still stick, remove the back casing and use this guide on how to clean
the buttons.
- If buttons are still unresponsive, see technician or refer to this guide on how to replace the buttons on the VI10.
Author
with
Chaitanya Ejner
25 Reputation
0 Guides authored
IUPUI, Team 1-6, Baechle Fall 2016 Member of IUPUI, Team 1-6, Baechle Fall 2016
IUPUI-BAECHLE-F16S1G6
3 Members
0 Guides authored
2 Comments
Bonjour j’ai un petit soucis ,la tablette n’arrive plus a s’allumer et je ne sais pas d’où peut provenir le problème
céline wang - Reply Share
Après le logo android je tombe sur l’écrit “ANDROID” et le cercle de chargement qui tourne sans cesse et l’appareil reste quand me ça pendant un long moment sans jamais démarrer.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 599
