Shield won't turn on
Opening the lid does not turn on the device
Drained/Dead Battery
Make sure to connect the charger to be sure the device is getting charged. There is a light on the back by the USB port that lights up when the Shield is being charged.
Nvidia Shield will not charge
If the battery will not charge, power off and reboot device with charger unplugged. Upon reboot, plug charger into the charging port located at the top of the controller. If neither of these suggestions work, a replacement charging cord, and/or standard 18650 lithium ion battery (2450 mAh) may be needed.
Blank display
It is possible that nothing appears on the display but the button with the Nvidia logo is still lighting up when the Shield is opened. If this is happening the display may have to be replaced.
Malfunctioning Gamepad
The gamepad does not respond to the user at all
Sticky buttons/Joysticks
Before opening the device, make sure there is no residue that may cause the button to stick down. Take a toothpick or pin to scrape away any residue under the buttons. Next, use a cotton swab with a solvent, such as rubbing alcohol, to wipe away the rest of the residue.
USB/HDMI Port Not Working
It is likely the USB or HDMI cable is bad than the USB port. Try another micro USB cable. If the new cable doesn’t work, the USB port may be damaged and will have to be replaced.
Display disconnects when connected to HDMI
Assure HDMI cord is securely connected to the HDMI port located at the top of the controller. Disconnect and reconnect to assure firm connection. If neither of these suggestions work, test the HDMI cord with another device assure HDMI cord is functioning properly. If not, your HDMI cord may need to be replaced.
Will not stream on my PC
Nothing is shown from my PC on the Shield display
Does not meet hardware and software requirements
Be aware that the hardware and software requirements for connecting the SHIELD to your PC are VERY specific. You can find the list of requirements here. http://shield.nvidia.com/user-guide/game...
Firewall blocks connection
Make sure that streaming is not being blocked by a firewall from the computer or the wireless router. Be sure to disable your firewall or add an exception for the device.
Games not supported
Not all games are supported for PC game streaming to the Nvidia Shield. Here is the current list of supported games. http://shield.nvidia.com/play-pc-games
Wi-Fi not working
Check to make sure the Wi-Fi for your Shield is turned on by going to settings, then Wi-Fi. Your shield may not be properly connected to the network, so try resetting the Wi-Fi option by turning off the device then turning it back on.
Author
with
Andrew Barbanera
376 Reputation
2 Guides authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
72 Guides authored
4 Comments
My screen does not work but when I open and close it slot it works and now it don't work at all
james turner - Reply Share
wifi still doesn’t work on the thing
i had it ofr 6 moths before it stopped connecting
Steampunk Sam Perez - Reply Share
It will not allow me to update system.
Orville Davis - Reply Share
i cant find the motherboard online where can i find it and for how much?
victor fields - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 15,037
