Will Not Turn On
You cannot boot up your Nook HD.
Drained Battery
The battery may be completely drained of power. Plug the Nook into a wall outlet using the power adapter and the 30-pin cable that came with the device. The Nook HD takes 3-4 hours to achieve a full charge.
Disconnected Battery
The battery may not be installed properly. Remove the battery then reinstall it, this can be done by removing the backplate then unscrewing the battery.
Dead Battery
Purchase and install a replacement battery.
Black Lines or Frozen Pixels on Display
Screen displays frozen pixels or lines.
Video Driver Malfunctioning
Try a soft reset of the device by holding the power button for at least 20 seconds, then release the button. Once the device is powered off, hold the power button again for 2 seconds to turn on the device.
Broken Screen
If the screen shows signs of being physical broken such as by displaying cracks, it will be to be manually replaced.
Not Holding Charge or Charging
Tablet holds only a short charge or cannot be charged.
Battery Issues
The software responsible for maintaining the battery's charge could be miscalibrated. Removing the battery before connecting the Nook to a power source should reset the device.
Broken/Bad Battery
The battery is broken or has become disconnected. First try to reinstall the battery, if that does not work you must replace the battery.
Broken or Unresponsive Screen
Nook HD boots up but the screen displays nothing or is unresponsive.
Unresponsive Screen
Try removing any SD cards and soft reset the device.
Broken Screen
Replace the screen.
Broken or Unresponsive Buttons
Buttons do not move or respond to input.
Soft Reset the Device
Press and hold the power button for at least 20 seconds then release the button. Once the device is powered off, hold the power button again for 2 seconds to turn on the device.
Button Jammed or Out of Alignment
Consult the guide on how to manually fix the broken or jammed button. The device will need to be taken apart in order to realign the button.
Author
with
Connor Pickert
320 Reputation
2 Guides authored
Cal Poly, Team 3-43, Maness Spring 2014 Member of Cal Poly, Team 3-43, Maness Spring 2014
CPSU-MANESS-S14S3G43
5 Members
60 Guides authored
3 Comments
Thanks for the soft reset info, Didn't realize the litlle silver button on the top right of the nook was the power button.
mike - Reply Share
I was playing a game…it froze up what do I do now?
Linda - Reply Share
Can't setup because, although connected to the internet it gives a message about slow wifi connection
Bernard Wright Sr - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 42
All Time: 28,952
