Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Motor Doesn't Start or Blade Assembly Doesn't Rotate
The mixer turns on but it will not run or spin the blades
Container and/or Lid is out of place
  • Make sure the container is securely locked on the motor base.
  • Make sure the lid is securely on the container in the correct position. It will be in the correct position if the arrows are aligned on both the base and the container.
Device is powered "Off"
  • The appliance is turned “Off”. Press the power button to turn “On”.
  • Check that the plug is securely inserted into the electrical outlet.
  • It is possible that the the circuit or fuse has overloaded from multiple appliances, so check that it has not blown and needs replacing.
Device is Overloaded
  • The unit has overheated or overloaded. Unplug and wait approximately 15
  • minutes before using again.
  • Check to make sure the unit is not overloaded with too many ingredients. If you feel it has too much, remove a little and try again. Be sure to gradually add ingredients in while mixing.
Audible click heard on button press, but motor remains still
  • if you can hear a click sound when activating the blender and a delayed click sound when deactivating it, the device might be suffering from a cold joint
  • One place worth checking for cold joint is a thyristor supplying the power to the motor.
Power Light is Blinking
The device is on but the power button continues to blink
Device is not Assembled Correctly
  • Make sure the pitcher/bowl lid is assembled properly aligning the arrow on the lid with the arrow on the handle.
  • Press down firmly on the handle until you hear a slight click to ensure it is fully engaged. The Ninja® Mega Kitchen System® will not run if the lid is not assembled correctly & is handle not fully engaged.
  • If using the Nutri Ninja® cup, make sure the blade is screwed on tightly to the cup. Align the tabs on the cup with the tabs on the motor base.
  • Turn the cup firmly to lock in place; you will hear a slight click. When the cup is assembled correctly the single-serve button will illuminate.
If you are still experiencing difficulties remove the cup from the base & turn the cup to change the tab orientation.
Micro-switches may be worn out
The easiest way to verify is by checking if the device refuses to work with one type of cup but not the other - specifically large jars vs small cups.
If your blender works with one type and not the other, the microswitch that is activated by the non-working cup may be damaged and require replacing.
Kitchen System Won't Crush Ice
Ice will not crush no matter what setting
Ice is not fully frozen
  • You must use the Nutri Ninja® cup or 72 oz. pitcher for this task. Be sure you have not used partially melted ice.
  • The blade may also be dull from use. Check to see if the blade needs replacing.
Food is Unevenly Chopped
The food is coming out chunky
Too much food has been added
  • Either you are chopping too much food at one time, or the pieces are not of even size and processing smaller amounts per batch.
Mixture Collects on Lid or Sides of Container
Smoothies and similar mixtures are sticking to the lid and sides
  • The mixture is too thick. Add more liquid
Author
with
Tommee Walker
877 Reputation
6 Guides authored
18 Comments
The handle on top of the blender keeps releasing and popping up when the blender is on
Edward - Reply Share
I've done all of the above and my blender still overheating. I don't leave it plugged in and I don't put too many ingredients in it and I turn it off and leave it off to cool off and still is overheating. Today it did it again for the third time (I had the blender put away for 2 weeks now) and now the cup is stuck in the blender and it's so hot. I tried to get it out and for an entire hr its still stuck I called ninja and they are unable to help me and I have no warranty. My old school bender has lasted longer than this I've only had it for a yr.
Jasmine Hylton - Reply Share
Pier light is blinking and it won’t run to use the large blender ?
Deborah Marie - Reply Share
power light is blinking (I have tried all the trouble shooting) and the cup won’t tried everything there too..
Kelly Snow - Reply Share
My Ninja blender model # BL770A blend, works for a few minutes and then stops, I have to unplug and plug it back again several time in order for it to work.
Johnny F - Reply Share
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 78
All Time: 7,972
