Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
D7000 Won't Turn On
The power switch is on, but nothing appears on screen and the camera doesn't respond.
Missing or Dead Battery
Check to make sure the battery is in the device and is charged. It could also be a defective battery. Try reinserting the battery.
Defective Rear LCD
Check the top LCD for a response. If the top screen is functional, it’s an issue with the rear LCD.
Corrupt Settings
Try restoring the camera to its default settings by holding the QUAL and +/- buttons together for more than 2 seconds.
Defective Lens
Sometimes a defective lens can prevent the camera from turning on. Try switching to a different lens.
D7000 Won’t Turn Off
The power switch is off, but I can still take pictures
Software Glitch
Occasionally a software issue can cause this problem. Remove the battery and leave it out for 12 hours. Put the battery back in and see if the issue is solved.
Faulty SD Card
If the camera still will not turn off, then try testing out new SD cards as a faulty card can cause problems.
Faulty Switch
If you’ve eliminated a software glitch, most likely the culprit is the switch. Replacing the switch is a good next step.
Blurry Images When Using Autofocus
The camera achieves focus lock, but the resulting image is blurry.
Lens Needs AF Fine Tuning
Some lenses aren’t adjusted perfectly from the factory and need adjustment. Nikon provides a nice guide here.
Defective Camera
Sometimes the body itself is out of adjustment. This is a common problem on the D7000. You may need to return the camera to Nikon or take it to a repair shop to get the body focus adjusted.
Viewfinder Out of Focus
My images are turning out clear, but the viewfinder appears out of focus.
Improperly Adjusted Diopter Adjustment
There is a small knob in the top right corner of the viewfinder. You may need to adjust this to make the image clear. If the knob doesn’t have sufficient adjustment to make the image clear and you wear glasses, you may need to order additional adjustment lenses.
Flash Doesn't Fire
I have the flash enabled, but there is no flash when I take a picture.
Flash is Disabled
Check if the flash pops up manually by hitting the flash button on the left side .If the flash does pop up, then it is an issue with the settings you are using.
Mechanism is Stuck
If it appears that the flash is not popping up all the way, gently pull it up as the mechanism could be sticky.
Flash Bulb is Burnt Out
If the flash is popped up but still doesn't fire, the flash unit may be defective.
Author
with
Thomas Willson
453 Reputation
1 Guide authored
Cal Poly, Team 24-6, Lancaster Spring 2015 Member of Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 Members
60 Guides authored
18 Comments
my slr d7000 flash not working manually not pop up when I press click the button pop up but no flash
sahathevan mahesan - Reply Share
My flash flashes but does not appear on the picture. No matter which settings. Front, rear, slow sync, plusorminus. Seems like the Synchronisation with the shutter does not work. External flash works perfect. Any ideas for me - except letting the whole electronic replaced?
Volker Kirchmann@gmx.de - Reply Share
The clock on the on the D7000 returns to a faulty setting, after the camera is used for a day or so, The camera date then needs re setting. The camera seems to be working peprfectly well otherwise. What is the cause and how can I fix this clock problem
dasquith - Reply Share
The video button does not function when pressed so i cannot do video
medsense88 - Reply Share
Camera won’t take a picture. The control panel says FULL. I think I may have hit the bkt button as I heard a continuous clicking. I’ve tried the 2 button reset. Help!!
Marilyn - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 113
All Time: 30,238
