Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Nikon Coolpix S70 Troubleshooting
Released Fall 2009, identified by model number 26189
Battery won't charge
The battery will not charge in the wall or with USB port.
Computer charge setting is off
If your battery is not charging, verify that the computer charge setting is on by selecting TAB > SETUP MENU > Charge by computer.
Drained/dead battery
If your battery will not charge, you may simply have a drained battery. Try a backup battery and be sure it is fully charged.
No image displayed on screen
My display screen is not responding.
Camera is not on
The display screen may not be responding because the camera might not be on. Press and hold the power button until display screen lights up.
Broken or cracked screen
If the camera display screen is not responding, you may have a broken or cracked screen. The screen may need to be replaced.
Unresponsive display
It is possible that it appears nothing is happening because the display is defective and may need replacement. First, check the connection and make sure there are no tears in the cables. If this is not successful, the digitizer will need to be replaced.
Black display screen
If your camera will turn on, but the display screen is black, try restarting the camera by turning off the camera and removing the battery. If restarting the camera is not successful in fixing the problem, a replacement of the display screen is needed.
Flash won't work
When a picture is taken, the flash will not go off.
Flash setting turned off
If the flash will not go off, make sure that the flash setting is turned on. Go to Menu> Flash Setting> On.
Burned out bulb
If the flash still does not go off after checking the flash settings, the bulb may be burnt out or broken. Buy a new bulb and replace it.
Lens error
When trying to take a picture, my camera says "lens error".
Low power
If your camera has a lens error message, your battery may not be fully charged. First, try recharging the battery. If this does not work, you may need to purchase a new battery.
Broken lens
If you have a lens error, the lens could be broken or cracked. To fix this, replace the lens by dismantling the camera and replacing the lens.
Blurry pictures
When viewing pictures on my camera, they are blurry.
Unsteady hands
If the pictures are blurry, you may have unsteady hands. Be sure that your hands are still when taking the picture or try using a tripod.
Dirty lens
If your pictures are blurry, you may have a dirty lens. Clean the lens before taking pictures.
Camera out of focus
If your pictures are blurry, your camera may be out of focus. Be sure to focus the camera before taking a picture, even after zooming.
Wrong memory card
If your pictures are blurry, verify that the memory card you are using is approved for the camera.
Author
with
Danielle Morris
177 Reputation
1 Guide authored
Texas Tech, Team 22-2, Rauch Fall 2015 Member of Texas Tech, Team 22-2, Rauch Fall 2015
TTU-RAUCH-F15S22G2
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 35
All Time: 1,835
