Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The camera won’t take a photo
You cannot capture that awkward underwater family moment.
Drained battery
First, make sure that the camera has some juice. Try charging the camera using an alternative electrical outlet in your home.
Dead battery
The camera may need a new battery altogether. Visit our battery replacement guide on the Nikon Coolpix AW130 homepage.
Stuck shutter button
Ensure that the shutter button isn’t stuck. The shutter button is located at the top of the camera, next to the on/off button. Since this camera is waterproof and often used by avid travelers, sand and dirt can become trapped in the button groove. You may need to use a soft towel to clean off the surface. If this doesn’t work, the button may need to be replaced.
Failing motherboard
The motherboard could also be faulty. If you have replaced the battery and your shutter button is A-OK, this chip-like controller may need to be replaced. Refer to the user manual, which can be found here. Also visit our guide on the Nikon Coolpix AW130 homepage.
My photos are dark
Your trip to Costa Rica looks a bit ominous.
Faulty flash button
First, try to turn your flash on. This button is a small lightning bolt on the back face of the camera. If the flash does not turn on, the actual button may need to be replaced.
Dead filament
If the flash is on and the photos are still dark, the filament, which is located in the center face of the camera, may need to be replaced.
My photos are foggy
If you were in Mexico, not Seattle.
Dirty lens
If your vacation photos are blurred, try using a soft cloth to clean the lens on the front face.
Auto focus settings
The auto focus is known to be indecisive or hesitant in this model. Try switching through the camera's various modes, taking a photo with each.
Condensation in camera
If this doesn’t work, you may have condensation in the lens. Though Nikon intended for this camera to be waterproof, moisture can still creep into the camera. Most of this moisture enters the camera through the battery door on the camera’s side. Wear can break down the seal. Open the battery door and remove the battery and SD card. From there, submerge the camera in a small bowl of water for at least a minute. Remove the camera, wipe the residual water from the camera body, and open the battery compartment once again. If there is water in this space, the camera’s battery door needs to be replaced.
The camera won’t turn on
No matter how many times you hold down that on/off button.
Dead battery
First, charge your camera. Perhaps try an alternative outlet in your home, as it could be an electrical issue. If the camera still won’t turn on, the issue could rest in the battery contacts. Open the battery compartment door and remove the battery. Using a soft cloth, wipe off the metallic battery contacts. Reinsert the battery. If the camera still won’t turn on, the battery may need to be replaced.
Defective motherboard
If, after replacing the battery, the camera won’t turn on it, the problem may rest in the motherboard. The motherboard is the camera’s “brain,” as it controls all basic functions. This may need to be replaced. Consult the manual, found here. Also visit our repair guide on the Nikon Coolpix AW130 homepage.
My camera won’t charge
If you just can’t give it life.
Broken charger
If the camera won’t charge at all, the problem may rest in the charger. Try to use an alternative charger and an alternative electrical outlet.
Grimy charging port
If this does not fix the issue, the charging port, a small metallic port in the battery compartment, may be ridden with dust or sand. Using canned air, clean out the small compartment. If this does not work, the charging port may need to be replaced.
My photos won’t transfer over to my computer
All you want is to create a nifty slideshow.
There are two means of transferring photos from the Nikon Coolpix AW130 to your computer – the SD card and the USB cable.
Bad memory card
If you are using the 32GB High Speed SD Memory Card, first ensure that the card is inserted properly. If all is good here, remove the SD card from its port and clean the SD port with canned air. Also clean the metallic contacts on the SD card. If this doesn’t help, try a different SD card.
Faulty SD Port
If all else fails, the SD port may need to be replaced.
Broken USB cable
If the photos won’t transfer over your computer using a USB cable, try cleaning out the Micro-USB cable port. This is inside the battery compartment. Similar to the charging port, this compartment can become ridden with sand and dirt. If cleaning does not work, try an alternative USB cable or alternative USB port on your computer.
Faulty Micro-USB Port
If cleaning the port does not work, the Micro-USB port may need to be replaced.
8 Comments
can aw 130 be reapaired if water is lodgged in?
Paras gogri - Reply Share
My GPS doesn’t work if it is cold. So if I let the AC blow directly on it the GPS won't work until it warms up
Gary Small - Reply Share
the zoom is blocked underwater only is working fine at the surface ??
hervé
herve guinvarch - Reply Share
Nikon aw130 volume on camera is shut off while playing back a video. cant figure out or find a solution
xrockfatherx - Reply Share
in my cameras show “cannot more locations” is there any limitation for save point for locations?
red.maroon.camp - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 56
All Time: 12,655
