Lens error
No matter what you do you can't get the lens to retract.
Jammed lens mechanism
This is a very common problem. Usually sand or grit gets inside the camera and interferes with the lens extension mechanism. Replacing the battery and restarting the camera should be your first approach. If this does not work try to blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. If the problem still remains, take the camera and try tapping it on the palm of your hand (cautiously) to dislodge any particles that may be jamming the lens.
Shutter fixture is broken
Replace the shutter fixture. See replace shutter guide.
Camera won't turn on
Your camera will not boot.
Dead Battery
A common problem that will prevent your camera from turning on is a dead battery. Try to restart your camera, if it's still not working it is most likely that your battery is dead and replacing them would be the best choice. If your camera is still under one year old, send it to Nikon and they will replace it with no cost.
Batteries not connecting
The battery may not be making a good electrical connection with the camera. Remove the battery and wipe the contacting ends with a clean dry cloth.
LCD black screen
The camera turns on, but the screen is blank.
Black screen
This happens a lot with digital cameras. This does not happen a lot with this series of Nikon, but it does happen. Restarting your camera would be your first step, if the problem is not solved try to replace the LCD.
Camera will not take pictures
No matter what you do, The camera will not take a pictures.
Camera is in the wrong mode
Change your camera's setting into shooting mode, the camera could be in a playback mode or etc.
Flash is charging
Wait until the flash charges fully. Try pressing the shutter button when the indicator is orange.
The memory card is full
Remove the memory card and unload pictures onto your computer to free up space on the memory card or replace the full memory card with a new memory card.
The memory card is not formatted correctly
Reformat the memory card. If this still does not work, try replacing it with another memory card.
The flash does not work
When shooting a picture, the flash does not work.
Flash mode is set to off
Make sure the flash setting is on.
PIctures are blurry or unfocused
The shots come out blurry when taking pictures.
Camera was moving while shooting the picture
Hold the camera steady while shooting.
Autofocus function hampered by obstruction to AF-assist beam
Do not block the Af-assist beam with your finger, or any other object while shooting a picture.
Object was outside camera's focus range
When the distance between the camera lens and the subject is very close switch the camera to macro mode. When taking pictures of subjects very far away set the camera to infinity mode.
andreas anggasastra
116 Reputation
5 Guides authored
Cuesta, Team 1-6, Zipperian Fall 2011 Member of Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 Members
60 Guides authored
1 Comment
The camera will go through all the motions, including flash but the image never appears on the screen. It will review perfectly with a bright screen. The battery voltage is 3.9. I deleted a lot of the images right on the camera. The test shots I made today have the date and time but no image.
Jackpol11
John Polasek - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 48
All Time: 19,628
