Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera does not turn on
When pushing the power button, camera does not turn on
Low battery
Remove the batteries from the battery compartment and insert new batteries.
Faulty motherboard
The motherboard runs the operation of the camera. It may have been damaged by dropping or other factors.
Camera turns off with short warning
With little or no warning, camera turns off unexpectedly
Batteries need to be removed
Remove the batteries from the battery compartment and reinsert them.
Camera or battery are too cold
Cold temperatures decreases battery performance and may not function correctly. Keep an alternate set of batteries warm and switch between two sets when operating your camera.
Sudden temperature changes
Sudden changes in temperature may damage a camera. If the camera or the batteries are too cold, the camera may not be working properly because of condensation. You can prevent condensation by keeping your camera in a case or plastic bag before exposing it to sudden temperature changes.
Lens error
Lens will not open
Low battery
Faulty motherboard
Motherboard problems can effect the battery life. The motherboard is malfunctioning or damaged.
Lens is stuck
Lens will not extend to take pictures
Turn camera off and on
Press the power button to turn off the camera and press it again to turn it on.
Remove any obstructions
Using a thin piece of paper, gently remove any obstructions by sliding it into the different levels of the lens.
Replace the lens
You may have a faulty lens that need to be replaced.
Flash does not work
When taking pictures, the flash does not occur
Flash mode is off
Turn on flash by first checking the setting for the camera, including the settings for the flash mode. Make sure the flash option is turned on.
Mode(s) do(es) not allow flash
Scene mode with which the flash does not fire is selected. To disable scene mode, enter shooting mode and press the shooting mode button.
Blink proof mode disables the flash. To turn off blink proof, select smart portrait mode. Then select the Menu button, then the smart portrait mode tab, then blink proof. Disable blink proof.
Broken/burnt out flash bulb
The bulb may be burnt out or broken. The only solution is to replace the bulb.
LCD does not work
LCD won’t turn on or only partially turns on
Low battery
Camera is on standby mode
Press the power switch, then the shutter release button, the camera button, or the movie record button.
LCD screen is cracked
Replace the LCD screen with the help of our guide.
Blurred photos
Pictures are unclear
Enable electronic VR Or motion detection
To use electronic VR or motion detection, press the menu button, select the setup tab and enable either mode using the arrow buttons on the camera and pressing the OK button.
Lens is dirty
Clean the lens with a microfiber cloth and lens-cleaning solution.
Faulty motherboard
Motherboard problems can effect the quality of photos. The motherboard is malfunctioning or damaged.
Patricia Diaz
130 Reputation
0 Guides authored
2 Comments
Nikon cool pix L27 is turn on but suddenly it turn off, I put new battries but it is not working .What is the exact issue.
Sanjay Singh - Reply Share
i have nikon coolpix L27 it starts but as i press the scene button it turns off..what should i do plz help
pooja - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 80
All Time: 5,744
