Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera won't turn on
After holding the power button of the Nikon J1 for several seconds, the camera does not respond.
Attach Camera to power source
Plug camera into it power source. The camera should begin charging, and a charging symbol will appear on the screen.
Battery is not installed correctly
Verify if the battery is installed correctly. Open the battery correctly and make sure that the polarity of the batteries is correct.
Power Button is not working
Spray compressed air into power button to ensure a good connection. This will clear debris that may cause a bad connection, that would prevent the camera from powering on.
"No Lens Attached" Error message
The screen displays a message informing the user that it does not detect the lens that is attached.
The camera will not let the user take pictures when this message is displayed.
Camera does not detect lens attached
Power the camera off and wait 30 seconds, then power the camera back on. This will reset the camera's settings, causing it to try and detect the lens again.
Camera has bad connection with lens
Remove the lens and reattach it while the camera is off. Remove the lens by pressing the button on the right hand side and rotating the lens assembly clockwise. Reattach the lens by rotating it counterclockwise onto the camera.
Gold connection pins are dirty
While the lens is detached, clean the gold pins on the lens and camera using a mixture of rubbing alcohol and water. Make sure components are dry before putting the lens back on.
Lens barrel is jammed
The barrel of the camera's lens is jammed, preventing it from extending and contracting.
Debris is caught in lens
Spraying compressed air will clean the guides for the lens, clearing any debris that may be obstructing the lens.
Lens has come off its tracks
Gently try to extend and contract repeatedly to try and correct the lens' path.
Camera Lens will not focus
The camera uses an auto focus feature, and sometimes does not focus itself correctly.
Focus is not calibrated
Power the camera off and wait 30 seconds to restart the camera. This will reset the camera's settings.
Switch the camera between its other settings i.e.(Picture, video, gallery ect.). This too will reset the camera's settings
Glass of the lenses is dirty
Finger prints and dirt can be the cause of blurry pictures. Use glass cleaner to clean all of the camera's glass lenses
Geoff Wacker
92,998 Reputation
88 Guides authored
12 Comments
how do you plug camera into power scource
redrobbo31 - Reply Share
you need to charge the battery externally from the camera. The J1 doesn't support USB charging.
Matthew Perkins - Reply Share
Cuando prendo la cámara dentro de la casa la imagen se ve oscura y no tira la foto sale una luz verde, pero afuera donde hay claridad se ve bien y dispara la foto
g.iris34 - Reply Share
Je ne peux pas faire de photos il est marqué problème d'objectif
Antoine Narove - Reply Share
My 1j1 zoom lens just blank out the shutter dint even open, on the screen dint says lens error just dark blank, what can I do?
donald abraham - Reply Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 88
All Time: 22,175
