Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera will not capture photos
With the tablet powered on, the camera will not capture photos, or photos are distorted.
Camera lens is cracked
If the photos you take appear cloudy or distorted, your camera lens may be cracked. Please refer to [these instructions] for replacing your lens.
Capture button is broken
If your camera will not capture photos when you press the capture button, the button may be broken. Please refer to [these instructions] for replacing your camera button.
No audio or distorted audio
With an audio file playing, the audio can’t be heard or is distorted.
Bad headphones
Try a pair of headphones that you know are working with your tablet. If the new headphones work, you will need to replace your old headphones.
Bad phone speakers
If you are unable to listen to audio through the internal speakers of the tablet, but are able to use headphones, the speakers may need to be replaced. Please refer to [these instructions] for replacing your speakers.
Screen is not functioning
The screen is black or the display is distorted.
Faulty screen
If the display is black or heavily distorted, the screen is likely broken and will need to be replaced. Please refer to [these instructions] for replacing your screen.
Software issues
If your screen is frozen or slow to respond, you may be having problems with the tablet software. Restart the tablet. If the screen still does not work, a factory reset could fix your issue. Please refer to [these instructions] for performing a factory reset.
Battery not charging or not staying charged
When plugged in, the tablet will not charge.
Faulty battery charger
If you have had a charger plugged into your tablet for 10-15 minutes, and it is not registering a charge, try a charger you know is working with your tablet. If the new charger works, your previous charger is faulty and will need to be replaced.
Faulty battery
If the device will power on only with the charger attached, and will not hold a charge, you probably have a faulty battery and will need to replace it. Please refer to [these instructions] for replacing your battery.
Author
with
Jake E
129 Reputation
1 Guide authored
2 Comments
NeuTab N9 Pro: While charging/plugged in the screen blinks with ‘NeuTab’ logo. blinking occurs every 5sec. 5sec on/5sec off
mcfaddenteam - Reply Share
Hola disculpa la molestia por favor podrías ayudarme a conseguir el Frimware E253430 de esta tablet NeuTab N9 Pro de mi madre Muchas gracias…
Noel - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 27
All Time: 801
