Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
DreamTab Becomes Overheated
My DreamTab's screen turns off while I'm using it.
Overheating
Do not expose your DreamTab to large amounts of heat. A common occurrence is leaving it in the car during hot weather. The temperature changes can harm a device because it can damage the motherboard.
Faulty Battery
If your DreamTab powers on only when the charger is connected, then the battery should be replaced. It is sometimes common to have a faulty battery and replacing it solves the problem most of the time.
Unresponsive LCD Screen
I am unable to operate my DreamTab because my screen is frozen. Frozen screens are a common problem in touch screen devices.
Burnt-out Display
It is possible the screen is not producing images because the display is burnt out. The display must be replaced.
Dirty Screen
The residue build-up on the screen may interfere with the multi-touch screen functionality. Cleaning the display with a lint-free or microfiber cloth will alleviate the problem. Having the screen with excess dirt can also make a device not respond since too much dirt has been built in.
Cracked Screen
If the screen is damaged, it is recommended replacing your display to avoid personal injury, and to restore functionality back to your device.
DreamTab Produces Distorted Audio
Sound cannot be heard through the speakers.
The Audio Jack Produces Distorted Sound in Headphones
The problem may be your headphones. Use another pair to see if that is the problem. If it is not, the problem might be interference from a damaged audio jack.
DreamTab is Muted
The muted icon displayed in volume settings shows a line through the speaker symbol. Press the volume rocker up to enable sound.
Headphones are Plugged into DreamTab
If headphones are plugged into the DreamTab, the audio will be sent directly to the headphones instead of the speaker.
DreamTab Fails to Charge
When I remove my DreamTab from its charger, it dies within minutes of usage.
Battery Drains Quickly
You may have an overused battery due to excessive charging, or a faulty battery.
Change Power Source
Try charging another device on the socket you are plugged into, to ensure that the socket is working properly.
The Charger is Damaged
Try plugging the DreamTab into a different charger if available.
The Battery is Dead
The battery may be unable to retain a charge and will need to be replaced.
Trouble Connecting to WiFi
My DreamTab has a weak internet connection and does not connect to a wireless network.
Tablet Cannot Connect to WiFi
Go to the "Parental Controls" located under "Mommy/Daddy Mode" and enable the internet connection.
Weak Router/Modem Signal
Make sure that you are within range of your wireless router, then confirm that the WiFi is enabled on your tablet. If neither solutions fix the problem, contact your internet service provider.
JayRam
264 Reputation
1 Guide authored
CSU Fullerton, Team 2-3, Bruce Fall 2015 Member of CSU Fullerton, Team 2-3, Bruce Fall 2015
CSUF-BRUCE-F15S2G3
4 Members
60 Guides authored
30 Comments
I have this tablet for my daughter and it has battery problems. I am looking for a replacement battery for this Nabi Dreamtab 8 Version B Tegra 4.
Thanks,
Brian Henry
Brian Henry - Reply Share
Broken product ! - Christmas gift for my son - Called twice on Hold for 1 hour - Please email me artemis101@gmail.com or call me 773-716-7147
artemis101 - Reply Share
Hi, I bought the dream tab for my child in 12/2015 for xmas. The screen is now frozen and we cannot get it to open. Not sure what we need to do. We try tuning it on and off and it does not help. Please help. Margo
Margoth Romo - Reply Share
This is happening to me!! Did you fix it?? My daughter can't play anymore. And I've been calling the nabi support team but they don't answer the phones.
anahiochoa982 - Reply Share
Im dealing with this now! Screen is frozen on android and the factory reset isn't working either. Did you find a solution?
rachels2321 - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 16,846
