Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Toy won’t turn on
Toy will not light up and play music.
Power switch is set to off
Make sure the power switch on the white panel above the yellow violin block is set to the “On” position.
Drained/bad batteries
If the toy will not turn on with the power switch set to “On”, check to make sure the batteries aren’t drained/dead.
Faulty power switch
If the toy has fresh batteries and the power switch is set to the “On” position, the power switch may be broken.
Faulty motherboard
If the toy has fresh batteries and the power switch is working properly and set to the “On” position, the toy may have a motherboard issue.
Keys are stuck
The keys are either not pressing down completely or not moving back to their original conformation.
Keys compress on one side
If the buttons are only pushing down on one side, and the toy is making the proper lights and sound there is no problem. The buttons are only intended to compress on one side like a hinge.
Keys will not decompress
If you push a button and it will not move to its original position, switch the on/off switch on the yellow face of the cube to “Off”.You will need to replace the button spring.
Toy has damaged components
There are visible parts of the toy that are damaged or broken
Corner pad is broken
If the corner pads are cracked or completely removed from the toy, you will need to replace the corner pad.
Battery door is broken
If the battery door is cracked or completely broken, you will need to replace the battery door.
Speakers
The speakers are either not loud enough or not playing.
Power switch is set Off
If the speakers are not working, check that the On/Off switch on the top of the yellow violin face is switched to the “On” position.
If the speakers are not working properly when the battery is switched “On”. Replace the batteries. Sometimes nearly or fully depleted batteries affect sound quality or volume.
Faulty speakers
If the speakers are still malfunctioning you are going to need to replace the speakers.
Faulty motherboard
If the speakers are still not working after turning the toy on, changing the batteries, and changing the speakers, by process of elimination the motherboard is faulty and must be replaced.
Panos Valavanis
275 Reputation
2 Guides authored
USF Tampa, Team 1-4, Sullivan Fall 2015 Member of USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
4 Members
84 Guides authored
1 Comment
i am in the Philippines. where can i have my childs magic cube repaired? It stayed in the closet for e few years without any battery installed. I wanted to use it for another child but it wont start or play even with fresh batteries... pls help me
marita_sevilla - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 2,072
