Unit Turns On But Does Not Brew
The power light is on, but the unit will not brew.
Power Switch
Before taking apart the Mr. Coffee machine, double check the switch by turning it on and off.
Adequate Water Supply
Your Mr. Coffee Maker will not work without water. Open the top lid of the coffee maker and check that there is enough water to brew your coffee. Additionally, there is a water-level gauge on the front side of the pot that displays the water in the machine. If there is not enough water to use, add more water and try brewing again.
Filter Positioning
There is a possibility that your Mr. Coffee maker refuses to work because the filter is off-centered or unbalanced. Open the top lid of the machine and reposition the filter. If the problem continues, then the filter may be misshapen and need to be replaced.
If this is the problem, find a new filter at the nearest home appliance store.
Dirty Machine
If your machine will not turn on, it is possibly clogged with minerals from your tap water. Fill the glass pot with 5 cups of white vinegar and hold the start button down for 2-3 minutes. When the coffee maker starts to heat, pour the vinegar through the filter. Then, rinse the machine out with water and attempt to brew another pot of coffee.
Bad Power Connection to Unit
It is possible that the machine is not working properly due to lack of power. Check your home’s breaker box and make sure that the circuit is on and working. If it has turned off, then reset the circuit breaker. If it is still malfunctioning, replacement of the power cord may be necessary.
See our Power Cord Replacement Guide.
Or Contact Mr. Coffee for cord replacements and repairs.
Cold Coffee
Your coffee is not warm.
There Is No Power
Be sure that the coffee pot is switched on and has access to power. The outlet that you are using may not be working. Also, be sure to check that the cord is completely plugged into the wall and there are no faults in the wiring.
The Auto Shut-Off Has Been Activated
When unused for a long period of time, the heating console will shut off automatically. There is no way to deactivate this function. Remove the previous pot and re-brew new coffee or reheat coffee separately.
Faulty Warming Plate
There could be an issue with the warming plate. If everything else is working and you have tried all of the above options, the warming plate may need to be replaced.
See our warming plate replacement guide.
Overflowing
The filter basket overflows and you come back to a mess instead of a pot of coffee.
Improper Placement of Filter
Be sure that the area where you place the filter is properly placed in the top of the coffee maker. The lid should close with ease and the tabs should fit into their proper holes.
Too Many Coffee Grounds
It is possible that you have placed too many coffee grounds into the filter. This will cause it to clog and not enough water to get through. Remove all grounds and try again, using the specified amount of grounds.
Improper Placement of Pot
The glass coffee pot may be incorrectly aligned with the warming plate. Place the pot and ensure that it is centered on the warming plate, and try brewing again.
Broken Spout
There could be hard water buildup on the spout from the filter to the pot, or it is damaged.
Coffee Grounds in Brewed Coffee
Every time you make coffee, there are coffee grounds in the decanter.
Improper Placement
Make sure that the coffee filter is properly situated in the basket. Improper placement results in coffee grounds flowing around the filter into the decanter.
Collapsed/Deformed Filter
In some cases, the filter may collapse or become deformed. If this is the case, the filter will need to be replaced. Collapsed and deformed filters allow coffee grounds to pass through into the decanter.
View our filter replacement guide here.
Base of Machine Surrounded With Water
You continuously find water puddles underneath your coffeemaker.
Pouring Excess Water
The problem may be that you are simply using too much water to brew your coffee. Locate the gauge that displays how much water you have poured in, and do not pour above the 12-cup mark.
Tubing Loose/Damaged
The high temperature tubing in the bottom of the machine could be loose or damaged from movement or heavy use.
Heating Coil Leak
Using strong cleaning chemicals to remove scale from the coffeemaker can damage the heating coil.
If the source of the leak is not from overflow water, turn the machine over (while empty), remove the screws from the bottom of the machine, and locate the source of the leak.
See our tubing replacement guide.
O-Ring Loose/Damaged
The warming plate may have melted or otherwise damaged the O-Ring, a rubber ring that lines the connection between the warming plate and the base of the machine. It is supposed to keep water from leaking through the base of the coffeemaker.
See our O-Ring replacement guide.
Madeline Landis
140 Reputation
1 Guide authored
Cal Poly, Team 10-31, Maness Winter 2014 Member of Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Members
72 Guides authored
115 Comments
Sunbeam Pro. Inc..
Boca. Ra Ton
Coffee Maker Model BVMC-ZHI
120VAC-950W-60HZ
Will not pour the Coffee Out
maryannesquivel - Reply Share
when coffee maker is turned on, the coffee maker gives a warning type beep and does not brew. Nothing in manual about a beep. Any ideas
Greg - Reply Share
Got the same problem.
Ezequiel Martinez - Reply Share
Same prob;repeated pushing--7 X--starts it gurgling and finally it stays on(MrCoffee BVMC-EJX37) .
Ed W - Reply Share
I just came across this as well. Any answers?
soniamgalante - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 122
All Time: 257,110
