Cell Phone will not turn on
Your Cell phone fails to turn on after pressing the power button.
Battery is not properly installed
Check that the battery is correctly installed in the casing, with nothing blocking the connection between the battery and the phone.
Refer to this guide for proper installation techniques.
Incorrect or damaged charger
Check that the charger is correctly plugged into the cell phone, if possible attempt to use another charger that will function with your phone.
Dead or damaged battery
Replace the battery. If this does not fix the problem, you may need to replace the logic board, as a connection in the phone is likely damaged.
Cell Phone has distorted or no audio
Your Cell phone sound quality is lacking, or completely nonexistent.
Bad connection
The phones speaker is connected with metal contacts. Check the connection between the logic board and the speakers to be sure it is properly connected.
Refer to the second picture on step 12 of this guide for help locating these connections.
Damaged Speaker
In order to fix a damaged speaker, you will need to replace it.
Refer to this guide.
Phone Turns on, but LCD screen stays black
Your cell phone will turn on, but the screen will not turn on.
Bad connection
Check the connection between the logic board and the LCD screen. Be sure it is firmly connected.
Refer to this guide for help locating these connections.
Damaged LCD Screen
Refer to this guide for replacing the LCD screen.
Phone keypad is broken or unresponsive
Your cell phone keypad does not respond when a button is pressed, or button(s) are broken.
Check keypad placement
Check that the keypad is positioned correctly in the cell phone.
Refer to this guide for help.
Replace the keypad
Refer to this guide for replacing your broken keypad.
Your phone is blocked by a SIM PIN
Your phone will not work correctly because it is blocked by a SIM PIN.
You incorrectly attempted to enter your SIM PIN 3 times
Refer to your Users Guide (page 23) for unblocking a SIM PIN.
Phone software is out of date
Your current phone software is causing compatibility or other issues.
Checking your phone software version
Find your current phone software version using this guide.
Update your software
To update your software follow the steps provided by the Motorola web site found here.
Your phone suddenly stops responding to anything
Your phone may have been working previously, but suddenly will not turn on, and the battery is not the problem.
Your phone is "bricked"
Refer to this guide for replacing your phones logic board.
Author
with
Jonathan Uder
1 Reputation
6 Guides authored
Cal Poly, Team 6-15, Maness Spring 2010 Member of Cal Poly, Team 6-15, Maness Spring 2010
CPSU-MANESS-S10S6G15
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,576
