Motorola V3c Troubleshooting
The screen won't turn on
The phone may be off
Have a friend call you to see if you are recieving anything. If you recieve a call, the phone is running.
The screen may be malfunctioning
If the screen does not turn on, it may have problems and might need to be repaired or replaced.
The cell phone won't turn on
Battery may not be installed
Check to see if your phone has a battery.
Battery has no charge
If it does have a battery, the battery does not have power and needs to be charged. If the phone still won't turn on after charging, you may need to replace the battery
The keypad does not work correctly
Short in the wiring
There may be a short in the internal wiring.
Moist Environments
If your phone has been in extremely moist environments, you may need to open it up and let it dry.
The outer casing is broken
Physical Damage
Your casing may need to be replaced, depending on the damage.
The camera does not turn on or fails to work
Broken wire or loose connection
There may be a broken wire or loose connection inside your phone. You may need to check and see if your camera's connection is secure.
Faulty Camera
You may also need to replace the camera.
Author
with
aaron gao
107 Reputation
0 Guides authored
Cal Poly, Team 11-4, Forte Winter 2010 Member of Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Members
96 Guides authored
1 Comment
out box messaging wont send
pam - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 3,163
