Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Wifi Will Not Connect
The phone does not connect to Wifi or says it is connected to WiFi but is unable to access the internet
Software Bug
By performing a forced restart, the phone will restore its WiFi connectivity. To perform a forced restart, hold down the power button for 10-20 seconds or until the Motorola logo appears on the phone screen. Check and see if the Wifi connectivity is restored.
Network Settings Reset
Sometimes the phone’s network settings are altered from factory settings and resetting them will restore WiFi connectivity. To reset the network settings, open settings on the phone. Once under settings, open system > advanced > reset options > reset Wifi, mobile, and Bluetooth > reset settings > confirm. This should reset the phone’s network settings and restore WiFi connectivity.
Corrupt Downloaded Files or Software
If the above solutions do not solve the problem the problem may be from something downloaded onto the phone. A factory reset of the phone may be necessary to fix the WiFi connection. To do so, go to settings > backup & reset > factory reset your phone. Before doing this, back up the phone’s data so it can be loaded once the reset is complete.
The Device Is Unresponsive
Touching the screen or pressing buttons on the phone gives no or very slow response times
Software Display Bug
Sometimes the best way to solve a problem is to just soft reset the phone. To soft reset hold down the power button for 10-20 seconds and the device will restart and go through its boot-up sequence.
Full Storage
Full storage on the phone can slow down speeds. This can be fixed by simply deleting pictures or texts, or by going to settings > storage and checking out what is taking up space and deleting what is not needed.
Out of Date Software
If the device becomes unresponsive when using an application make sure to soft reset the phone and make sure the applications software is the most up to date on the google play store. The device’s software may also be out of date. Go to settings > system > advanced>system updates and make sure there are no updates available.
A factory reset may be necessary if the problem persists if the other suggestions fail. There is probably a deeper seeded software problem. Go to setting > backup & reset > factory reset your phone. This will delete the phone’s data so a backup is highly recommended to keep the phone’s data safe.
The Device Is Stuck on a Black Screen
The screen is black or will not turn on
Similar to the unresponsive screen a soft reset often solves the problem. To soft reset hold down the power button for 10-20 seconds and the device will restart and go through its boot-up sequence.
Battery Is not Sufficiently Charged
Sometimes drainage of the battery leads to a system crash. This may because of services or components not being properly shut off. To fix this plug the phone into a working charger, leave plugged in for around 10 minutes, and after this time hold down the power button for 10-20 seconds.
The Battery Will Not Charge/Hold a Charge
Battery drains unexpectedly quickly or will not charge at all
Faulty Power Cable/Adapter
Confirm that the power cable is functional by attempting to charge a different compatible device. If the device fails to charge, consider buying a new adapter.
Malfunctioning Charging Port
Ensure the charging port is clear of all dust and contaminants. Check if any parts are loose and that the central tab in the USB port is not misaligned. If misaligned, gently use the spudger to lever the tab back into place.
Missing Operating System Update
Go to your system settings and make sure any new software updates are installed. After, fully restart the device. If battery degradation persists, continue to the Faulty Battery section.
Faulty Battery
If the power cable is functional and the device only powers on when the power cable is plugged in, the battery may need to be replaced. Replace the battery using this guide.
The Phone Is Overheating
The phone is hot to the touch while in use or charging
CPU Is Busy
This occurs when there are too many apps open or a single app is using a large amount of memory. Simply close the apps and reduce phone use until it cools down. If the issue persists, an app that tracks the phone’s battery temperature can warn of possible overheating.
Old Battery Is Overheating
If the phone still has the original or older battery, it may release more heat than a newer battery. The easiest way to do this is to replace the battery. To do so, use this guide.
Phone Overheats While Charging
Sometimes the phone will overheat while it is charging, this is likely due to using a charging cable that did not originally come with the phone. This can be solved by using the original cable again or purchasing a new cable.
The Camera Takes Blurry Photos
Your photos appear out of focus or completely black.
Dirty Lens
If your photos appear blurry or if the camera fails to focus, you may have oil or dirt build-up on the lens. If this is the case, clean the lens with a clean, soft, and dry cloth.
Faulty Camera Settings or Third-Party Application
Your camera may have the Camera Error message pop up or not launch because of a third party application or the camera settings. Close all third-party apps that may use the camera. Go to Settings -> Apps -> Camera and press Force Stop. Clear your data and cache and the problem should be corrected.
Photo Settings
Increase the resolution (photo size) in the Camera app. A smaller photo size results in lower image quality. Avoid zooming in when taking a photo, this causes pixelation. Be sure to disable the burst mode as this can impact image quality.
Broken Lens
If there is a visible crack your lens, visible discoloration, or magnification when your camera is launched your lens may be broken. Replace your lens using this guide.
Benjamin Fields
179 Reputation
0 Guides authored
Cal Poly, Team S19-G6, White Winter 2020 Member of Cal Poly, Team S19-G6, White Winter 2020
CPSU-WHITE-W20S19G6
4 Members
72 Guides authored
7 Comments
my phone got wet and wont start
Lonnie Hergenrider - Reply Share
how do i start my phone after getting wet
Some of my apps aren't responding. How do I fix it? I have a Motorola Moto g7 play.
mamagray5352 - Reply Share
Mine too! I have to constantly restart the phone to get the apps to work.
Robbie Moreland - Reply Share
Call not working hang phone moto g7 any file install please tel me
Basheerahmad Shaik - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 56
All Time: 8,090
