Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Motorola Moto G4 Plus Troubleshooting
Released June 2016, identified by model number XT1644
Distorted or Nonexistent Audio Output to Headphones
You have trouble listening to sounds on your phone.
Residue Filled Audio Jack
If you detect physical residue in your headphone jack, clean it carefully using narrow and thin objects. Check by plugging in headphones and see if they work.
Unplugged Headphones
If your headphones are loose or not plugged in well, apply some force to them and push them gently until a click is felt. Check that the headphones adapter is fully inserted.
Faulty Headphones
If you still hear no sound, you may need to replace the headphones.
Broken Audio Jack
If the problem persists, it is likely that your audio jack is broken. Replace the jack using this guide.
Phone Will Not Turn On
The phone will not respond or power on.
Uncharged Phone
Your phone’s battery may be dead. Plug in the charger, wait a few minutes, and turn on the phone.
Defective Phone Charger
Make sure your phone charger is plugged in and is functioning. Try charging a similar device with the same cable to find out whether or not the charger is faulty. If your charger is not working, consider purchasing a new one.
Worn Out Battery
Your battery is defective if the phone charger is functioning properly but the phone will still not turn on. Replace your battery using this guide.
Stuck or Nonfunctional Volume Buttons
Your volume button is stuck in place, or you cannot change volume.
Dust or Dirt Build Up on Buttons
If your buttons have dust or dirt build up, try wiping the cache partition with a soft dry cloth and press and hold on the buttons several times. If the problem persists replace your buttons with this guide.
Unresponsive Screen Or Display
Your phone does not respond to touch commands
Third Party Application
Your screen is unresponsive due to a recently downloaded application. Restart your phone.
Screen Malfunction
If the problem persists after restarting your phone, replace the screen using this guide.
Camera Takes Black or Blurry Photos
Your Photos appear out of focus or completely black.
Dirty Lens
If your photos appear blurry or if the camera fails to focus, you may have oil or dirt build up on the lens. If this is the case, clean the lens with a soft cloth.
Faulty Camera Settings or Third Party Application
A third party application or camera settings is causing your camera to not launch or the Camera Error message to pop up. Close all third party apps that may use the camera. Go to Settings -> Apps -> Camera and press Force Stop. Clear your data and cache and the problem should be corrected.
Broken Lens
Your camera lens is broken if there is a visible crack your lens, visible discoloration, or magnification when your camera is launched. Replace your lens using this guide.
Andre Rives
2,839 Reputation
4 Guides authored
USF Tampa, Team S2-G6, Sullivan Spring 2017 Member of USF Tampa, Team S2-G6, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G6
4 Members
72 Guides authored
1 Comment
Boa noite! Abaixei a ultima versão do android 7.0 e não gostei, gostaria de saber se tem como eu voltar para versão 6.0. Obrigado Meu nome é Fernando e meu email é fasantosjc@yahoo.com.br
nogueira.santos2007 - Reply Share
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 31
All Time: 1,405
