Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Moto E will not turn on
After holding on button or charging you still can't get the screen to turn on
Bad/damaged screen
Check the screen for any signs of damage i.e. cracks or gouges. A replacement guide can be found here.
Bad/Damaged Motherboard
If the phone still will not turn on, it is possible the logic board is bad or has been damaged and must be replaced. A replacement guide can be located here.
Bad battery
After checking the screen, try plugging the phone into your supplied charger. (The one that came with the phone.) A guide can be accessed here to replace the battery.
Moto E is stuck in boot cycle
After the phone screen is turned on it will not continue onto the home screen
Memory is too full
Sometimes this issue is caused by the storage built into the phone is full and the phone is not able to load the boot software. Plug the phone into a computer and erase all unnecessary files.
Bad or Damaged Motherboard
This issue is most likely caused by the motherboard being bad or broken and must be replaced. Replace the motherboard yourself by following the guide here.
Moto E has cracked/damaged screen
The screen is cracked or damaged
The phone was dropped or damage occurred
Replace the screen using screens and digitizers sold on iFixIt. Follow the guide to replace the cracked or damaged screen here.
The volume buttons are unresponsive
The volume buttons will not respond to anything regardless of the software opened
Button's housing has become dirty or clogged
This is sometimes caused by the buttons being obstructed by debris.
Broken/bad button assemblies
This can be caused by the buttons being damaged. Replace the button assemblies by purchasing a new assembly and replacing it here.
Phone turns off after charging
The Moto E will not boot after the phone has been unplugged from the wall or USB charging port
Bad battery
The battery has become damaged or "worn out" and will need to be replaced. It is fairly simple to replace the battery, and you can do that yourself by clicking here. A guide can be accessed here to replace the battery.
Malfunctioning Camera
The rear facing camera is not working or is not properly functioning
The camera has become damaged
This is sometimes caused by the camera being water damaged or broken. You can replace the camera assembly by following the guide located here.
Visit the Device Page '''Here'''.
Alex Craig
2,611 Reputation
5 Guides authored
24 Comments
my moto e fall down & display is off show nothing but the touch working properly,what can i do ?
jitesh - Reply Share
swap this to
swapneildash2 - Reply Share
Hey there my moto e 1 generation is not turning on it only shows the symbol of moto and does not proceed further......what is the problem with my phone
chini275 - Reply Share
Same problem with me as well...what have you done
Aakash Abhani - Reply Share
My moto e 1st gen is not switching ON it only shows Moto symbol, I opened boot menu nd tried all the options of recovery, factory, normal setup..but nothing seems to work, also no command symbol comes. Battery is draining on its own...What to do in this case ??
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 46
All Time: 44,065
