Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Dead or Unresponsive Battery
Dead Battery
If your DROID Mini has a quickly dying battery, or won’t turn on, you may have a dead or unresponsive battery. If your battery is completely drained, and charging the phone doesn’t have an effect, then the battery may be dead. If this occurs, replace your phone battery.
If you find that your phone battery drains quickly or more often than is usual (about 28 hours of mixed usage), then you may need to replace the battery.
Lack of Battery Charge
If your battery is unresponsive, that is the battery is below 5%, some of your DROID Mini’s functions may not be available. For example, the camera may not function due to lack of battery power. The way to fix unresponsive phone functions related to battery life is to fully charge the battery. If the problem persists, restart your phone after charging the battery.
Broken Back Case
Your DROID Mini may experience some physical damage, causing the outer front or back case to crack. If damage occurs, the best option is to replace the broken part. Refer to the case replacement guide to learn how.
Cracked Screen
If your phone’s display is not showing up you might want to restart the phone. If that doesn't work consult the screen replacement guide.
Camera Malfunctioning/Camera Not Starting
Restarting Your Phone
If your camera is failing to work the first things you might want to do is restart your phone. Another option would be to force stop your application by exiting out of it and launching it again.
Settings
The failure of your camera may also be a direct cause of your current phone settings. Whether you unintentionally changed a setting or purposefully changed a default setting, resetting a function to default settings may solve the problem.
Camera Lens
The DROID Mini’s lens might also be the issue. The lens might be cloudy or otherwise dirty. Cleaning the lens with a lens cleaner and scratch-free cloth will solve any cloudiness or blurriness related to this lens.
Memory
The failure of your camera may have to do with your phone’s memory. Usually the phone will notify you that your camera’s memory capacity is full and you might need to delete or allocate your photos elsewhere.
Battery
If you DROID Mini’s camera still does not function, the battery may have to do with the failure of your camera. If the phone’s battery is too low you might be unable to access the camera application. Charge your battery and then try using the camera again.
Broken Camera/Flash
If your camera is broken, or if the flash has stopped working, consult the camera replacement guide.
Loudspeaker
Blown Speaker
If your speakers are rattling, or you are hearing crackling or a static noise,you may need to replace the loudspeaker. Consult the loudspeaker guide.
Author
with
Alec Fales
337 Reputation
2 Guides authored
USF Tampa, Team 9-2, Leahy Fall 2014 Member of USF Tampa, Team 9-2, Leahy Fall 2014
USFT-LEAHY-F14S9G2
3 Members
60 Guides authored
10 Comments
My Droid Mini is having issues with motion sensor. When phone goes to sleep the clock continues to flash as if phone is moving when it's not. Also auto screen rotate doesn't work.
Ron Whittaker - Reply Share
My Motorola Droid Mini xt1030's won't turn on long enough and the logo when you first turned it on won't show up.
Rosanna - Reply Share
My flash won't work on my Droid Mini HELP !!
Moni - Reply Share
Sound prooblem
asif abbasi - Reply Share
Sound problem
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 9,527
