Student In Progress
This wiki is being worked on by hardworking students.
Automatic Shut Off Due To Inactivity
The Monster Superstar S310 may automatically power off when it has been inactive for an extended period of time due to the speakers built in power saving features.
- Speaker will shut off automatically due to the speakers built in settings
- Try to power it back on and reconnect
- Opening the Bluetooth settings on your mobile device
- Play music to see whether the speaker stays powered on
- If the speaker continues shutting off while actively playing, the problem may be related to the battery or another component
Worn Out/Faulty Battery
Having a battery issue can be caused by a loose connection and this can interrupt the flow of electricity causing the speaker to cut out or lose power unexpectedly.
- Replace battery and connectors allowing a fresh power connection
- Try taking out battery and cleaning connectors
- Look for dirt or grime that could be stopping the power from continuously going
- Users can try to remove dirt or grim by cleaning with a cotton swab and isotropic alcohol
- If speaker shuts off. shortly after charging, the battery might be damaged and need to be replaced
Dirty or Water Damaged Internal Parts
The Monster Superstar S310 boasts a "IPX5 Water Resistant Design" but it is not waterproof. Water or grime entering the speaker may damage the electrical components and cause the speaker to not function right or at all.
- Water or other liquids may have damaged the speaker
- Turn the speaker off and disconnect from any power source
- If there is dirt or grime anywhere on the speaker use a gentle brush and clean speaker till no more dust is visible
- If the internal parts of the speaker need to be evaluated, follow these instructions to help you take the device apart <instructions page not made yet>
- Try to avoid daily wear and tear by protecting the speaker and not allowing liquids near or being rough can help speaker last longer
Overheating Due to Extended Use
This speaker may have become too hot due to extended use, over charging, or being exposed to high temperatures. Excessive heat can damaged the device or cause it to shut down.
- Speaker can overheat and power off
- It's best if users can let speaker rest in a cool area before trying to power back on
- Once the speaker is back to normal temperature, turn it back on and test to make sure its working normally
- If speaker sounds damaged or not working right, stop using until looked at or taken apart following the correct instructions guide
0 Comments
