Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device won't pair to the Mio PAI app
Your Mio Alpha 2 will not pair or stream to the Mio PAI app
Your Device Lost Bluetooth connection
Open your phone’s Bluetooth settings and forget all Bluetooth devices. Then, close all open apps.
Check Your Bluetooth Distance
Ensure your phone and Mio product are within the 30 meters/100 feet Bluetooth distance. Note: There may be interference by objects that prevent the Bluetooth transmission from your device to your phone including water, your body, etc.
New phone software froze the watch
You updated your phones software and it the watch is stuck
Reconnect your watch and update the app
If your watch is stuck after you updated your phone's software, you might need to reconnect your watch via Bluetooth and updated the app. Search for https://support.mioglobal.com/hc/en-us/a... and follow the steps provided.
Mio Alpha 2 firmware on Android needs to be updated
You need to update your devices firmware on your Android phone
Step 1: Make sure your Mio device isn’t paired with your phone
Go to your phone’s Bluetooth settings. You’ll see a list of nearby Bluetooth devices. If you see your Mio appear in the Paired Devices list, tap its name and select ‘Unpair’ or ‘Forget’.
Step 2: Close the Mio GO app
Tap the Recent Apps icon at the bottom. A list of running apps appears. Swipe right, or click the X in the left top corner on the Mio Go app picture to close it.
Step 3: Make sure you are using the latest version of the Mio App
Visit the Google Play Store and update your Mio GO app to the latest version If you have the latest version of Mio GO, open the App now.
Step 4: Update your Mio device firmware
Open the Mio GO app and connect to your device. You will get a message to update the firmware. Select OK and follow the prompts.
Step 5: Firmware update successful
After the update, a message that the firmware has been updated will appear.
Mio Alpha 2 firmware on IPhone/IOS needs to be updated
You need to update your devices firmware on your IPhone
Go to your phone’s Bluetooth settings where you’ll see a list of nearby Bluetooth devices. If you see your Mio appear under My Devices, tap the ‘i’ beside its name and select ‘Unpair’ or ‘Forget’.
Press the home button twice and swipe up on the Mio GO app to close it.
Step 3: Make sure you are using the latest version of the Mio GO App
Visit the App Store and update your Mio GO app to the latest version. If you have the latest version of Mio GO, open the App now.
Open the Mio GO app and connect to your device. You will get a message to update the firmware. (If the GO app doesn’t ask you to update, you can manually update firmware in Mio GO by opening the Mio GO app. From the top left menu, select “Help” then “Software Update.” Select your Mio device and update.) Select OK and follow the prompts.
After the update, a message that the firmware has been updated will appear. Your Mio device will now be working normally.
Bluetooth Connection Isn't Working
Your Bluetooth on your watch is not working
Reset your Mio Alpha 2
If you were previously able to connect to smartphone apps but now you cannot, a factory reset will restore your Bluetooth Smart (4.0) connection. Follow this sequence to perform a factory reset:
Step 1:
Hold both buttons for 2 seconds (until you hear 2 quick beeps), and then keep holding the right button but let go of the left one until it shows the system info.
Step 2:
Release the right button
Step 3:
Press the right button once
After that ALPHA2 will be reset, and any saved workout files or device settings will be deleted. Press and hold any button to wake ALPHA 2 up. You can manually reconfigure your device settings with the buttons, or connect to Mio GO to restore the settings saved there.
Author
with
David Soder
155 Reputation
1 Guide authored
IUPUI, Team S22-G3, Bayer Fall 2017 Member of IUPUI, Team S22-G3, Bayer Fall 2017
IUPUI-BAYER-F17S22G3
4 Members
24 Guides authored
1 Comment
How can I get the updated MIO GO app as it already phase out in Appstore.
Tony Ho - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 40
All Time: 7,467
