Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Chuck getting stuck or wobbling
Bit may not be inserted properly
Verify that the bit is centered in the chuck and that the chuck is tightened completely. To do this, rotate the chuck counter-clockwise to release the bit or prepare it for bit insertion. Insert only the shank (portion with no cutting edge/flutes.) Make sure the bit is not at an angle, then rotate chuck clockwise to tighten (rotate until you hear clicking from the chuck.)
Chuck may be faulty
This drill often has issues with the stock chuck. If possible, replacement under warranty may help. Otherwise, the most consistent and effective solution is to replace it with a different chuck (Recommended brand: Rohm.) See this guide for help replacing the chuck.
(Note: the guide does not exist at the moment, but it will be hyperlinked once it is added.)
Trigger does not push in or stuck
Control switch is locked
The control switch has three positions: forward, lock and reverse. If the control switch is placed in lock position; lock position means the control switch is in center position; the trigger will push and appear stuck. When using the drill make sure the Control Switch is in forward or reverse depending on what the project is. Forward rotation means the control switch is pushed from the right side. Reverse rotation means the control switch is pushed from the left side.
Trigger is obstructed
When removing the battery pack or before maintenance always lock the trigger by putting the control switch in center position.
Remove the cover first with a screwdriver, the Milwaukee Drill cover will have eight screws to remove. After removing the eight screws take the cover off slowly. Once the cover is off checking the trigger and make sure any wires are not interfering with the function. (Photos and link will be added).
Battery does not charge
Charging terminals are dirty
Ensure that the battery is correctly inserted into the charger and that the charger is free of grease, dirt, or dust buildup.
Faulty electrical outlet
Try the charger on a different outlet to determine whether the outlet is working. In the event that the outlet is functioning, replace the charger with a new one since the problem may arise with the charger itself.
Battery is not properly seated
Make sure the battery is securely attached to the drill by pushing it in until it is firmly attached. Ensure that the battery has been fully charged.
Belt Clip breaks or fall off
The belt clip falls off the drill or breaks off the drill.
The belt clip needs to be reattached
Make sure you have the belt clip, one screw that can fit through the belt clip holes, and a screwdriver. Once you have the materials line the belt clip on the one hole on the drill’s handle. Once belt clip is lined up with the with that hole on the handle of the drill screw in the belt clip into the drill and make sure the screw and belt clip are tight to the drill.
The belt clip needs to be replaced
If the belt clip gets bent off or breaks the whole clip needs to be replaced. Unscrew what is left of the belt clip off the drill. Get the new belt clip and line it up with the hole in the drill’s handle. Then using a screw and screwdriver screw the belt clip tight to the handle of the drill. Make sure the belt clip is snug and tight to the drill so the belt clip will not fall off. See this guide for more help on replacing the belt clip:
Drill does not spin or powerup
Drill is not charged
Battery is not charged and or faulty and needs to be replaced
Switch is not pushed in
Make sure that the actuator (forward/reverse button) is fully pressed before rotating in either direction.
Reverse Switch stuck/does not push
Battery may not be supplying power
Test the battery for power. Test the battery by placing the battery on the charger for an hour minimum. After the hour or more take the battery off the charger and test the power.
Control switch may be faulty
If the control switch is not seating properly or not functioning as expected, it’s possible it may be broken or otherwise defective.
To replace the control switch, refer to *this guide*
(Guide does not currently exist. Will be added later.)
Connor Kramer
116 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,028
