Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Failure to Interface with External Devices
Computers, amps and other external devices do not recognize outputs from the keyboard.
Damaged Wires and Plugs
Make sure that the wires and plugs are in good condition. If the cables are frayed or the plugs are damaged at the ends, replace the cables.
Outdated Software
The keyboard requires a specific program to operate properly with a PC. Should the software be out of date, go here to download up to date software. Once the page has opened you will see three sections labeled “Series”,” Product”,” OS”. Under “Series” click on “Legacy”, then under “Product” click on “Oxygen 8”, and lastly choose the type of operating system your computer runs on. This will allow you to download the software necessary for the keyboard's proper operation.
Failure to Power On
Device does not respond to any inputs and the LED screen does not light.
Faulty Power Adapter
Ensure the 9V DC power is plugged into a working electrical socket. If it is, but there are still no signs of power such as the LCD screen turning on, function any of the switches. Test the output of the AC-DC power pack with a voltmeter. If the output tests between 9.0-9.5 V DC, then it working. If it does not indicate voltage, or the voltage is above or below the indicated range, the power adapter must be replaced. It should only be replaced with a 9V DC 500mA <->120V AC 60 Hz adapter.
Damaged Ports on Back of Keyboard
Check ports on back of keyboard. If the port you are using is damaged, replace it using the provided guide located here.
Failing to Power on, on USB Power
Check if adapter power or batteries corrects the issue, if it does, USB is the issue. Ensure all USB plugs are inserted properly and that all cables are less than 5 meters long for USB 2.0 and 3 meters long for USB 1.0 or if you are unsure of the type. If still no power, try utilizing a different port on the computer and check the task bar for any error messages related to input devices.
Failing to Power on, on Batteries
Install new batteries and power on the device. If still no power, remove the batteries and visibly check the battery contact that is visible for corrosion. If there is corrosion, then both contacts are likely corroded and must be cleaned.
Device Function is Unresponsive or Intermittent
Keyboard response does not match or does not even recognize user inputs.
Pitch Bend Wheel or Modulation Wheel are Unresponsive
The potentiometer inside the switch may have gone bad or has a faulty connection.
Rotary Controller Knobs are Unresponsive
The trim potentiometer inside the knob may have gone bad or has a faulty connection. This guide shows how to replace/repair the internal trim potentiometers.
Keys are Stuck
If there is a stuck key, the cover disassembled, and the key assembly must be freed. A guide on how to disassemble the key assembly is located here.
Keys are Loose
If there is a loose key, the device must be disassembled, and the key reattached to the keyboard assembly. A guide is located here.
Keys are Unresponsive
Keyboard may have damaged connection or toggles. A key repair guide is located here.
Device is Power On but the LCD Screen is Unresponsive
The LCD screen may be damaged and must be replaced, This guide shows how to replace the LCD screen.
Scott Miller
437 Reputation
4 Guides authored
USF Tampa, Team 1-6, Sullivan Fall 2016 Member of USF Tampa, Team 1-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G6
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,403
