Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Battery Loses Power too Fast
Phone loses power quickly
Excessive Screen Brightness
If the screen is too bright, it can cause the battery to drain. A solution is to turn off the automatic brightness and turn the brightness to low. Go to Settings, then go to System, then Display. From here, you can turn off the automatic brightness and turn the brightness to low.
Pending Software Update
If a software update is pending, it can drain the battery quickly. To stop a pending update from draining your battery, you must update the software. To do this, go to Settings and update to the newest version.
Automatic Updates Draining Battery
If your Microsoft Lumia 640 XL is set to update automatically, the automatic update can drain the battery quickly. Go to App Store application to turn off the automatic updates.
Phone Won’t Charge
Phone will not charge
Damaged Phone Charger
If the charger is faulty or has damaged wiring, it will not charge the phone. Check to make sure the charger is working by testing it with a compatible phone or check to see if phone will charge with another compatible charger.
Old Battery
If the battery is old, it may no longer take or hold a charge. To replace, see our replacement guide.
Dead Battery
If the battery is dead, your phone will not charge. To replace, see our replacement guide.
Phone Won’t Turn On
Microsoft Lumia 640 XL will not turn on
Not Sufficiently Charged
If your Microsoft Lumia 640 XL does not power on, make sure that it is charged. To charge the phone, take a phone charger with a Micro-USB and plug it into an outlet. Take the Micro-USB end of the charging cord and plug it into the phone. The phone will take about 2 hours to fully charge.
Full RAM
If your Microsoft Lumia 640 XL does not power on, restart the phone to clear out the full RAM. To restart the phone, find the power and volume buttons on the Microsoft Lumia 640 XL and hold them down at the same time. Do this until the device powers down, then let go of the buttons and the Microsoft Lumia 640 XL will turn on.
Phone Software Out of Date
To update the software, plug the phone into a computer. To plug the phone into a computer, take the Micro-USB end of the cable and plug it into your phone. Then take the USB end of the cable and plug it into a computer. After plugging the phone into a computer, the computer will recognize the phone and display your phone in a Phone Selection screen. The available software for the phone should be displayed on the computer. Then select “Install software” or “Reinstall software.” This will download the software to your phone.
Can’t Connect to WiFi
Microsoft Lumia 640 XL won’t connect to the WiFi.
WiFi Disconnection
If your Microsoft Lumia 640 XL can’t connect to your WiFi, you might have to reset your device. Go to Setting, System, Reset Your Phone, from there you can reset your phone.
Bluetooth Interference
If your Microsoft Lumia 640 XL is connected to Bluetooth and WiFi at the same time, it can cause interference, making it so that the WiFi connection is not functional. To turn off the Bluetooth, go to Settings, Devices, then Bluetooth, from here the Bluetooth can be shut off.
Laggy Router
If your phone is not connecting to WiFi, you may have to reset your wireless internet router. To reset your wireless internet router, first unplug the router from the outlet. Wait 20-30 seconds after unplugging the wireless internet router. Then, plug the router back into the outlet and wait about 2-3 minutes for the WiFi to come back on.
3 Comments
My lumia 640xl can't open store app.. After a few second popup come out
This error cod may be helpful : 805a0190
Can help me to solve this problem.
District JB - Reply Share
My lumia640xl blue screen showing turn on
madhusudan mohanty - Reply Share
My lumia640xl Stuck on red screen
Hamza Houssein - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 25
All Time: 1,784
