Student In Progress
This wiki is being worked on by hardworking students.
Marshall Emberton III Audio Sounds Muffled Over Time
When playing audio from the speaker, it comes out muffled or otherwise distorted.
Dirt or water may have gotten inside the speaker
Although waterproof like previous models, dirt and/or water can still get inside the speaker and distort the audio.
To remedy this get some form of compressed air and blow it in the speaker's direction but not directly inside the speaker. If this does not work see our main speaker replacement guide.
Audio cuts in and out at random
Erratic behavior such as the speaker audio cutting in and out or pausing at complete random can be fixed using a factory reset.
How to perform a factory reset:
- Remove Emberton III from your Bluetooth device list.
- Push and hold the power button to turn the speaker on.
- Push and hold the Bluetooth button for 7 seconds. The Bluetooth indicator turns quickly red, and the speaker restarts.
- The speaker has returned to its factory settings and is ready to be paired
For a more detailed look, see the factory reset guide on the Marshall website.
If this does not work be sure to download the Marshall Bluetooth app and make sure your speaker is updated to the correct firmware.
Speaker Out Of Range
Your paired device being out of range of the speaker can distort the audio as the speaker only has bluetooth range of up to 100 meters (about 328 ft.) in an open field. Teetering on the edge of this range can cause the audio to distort so make sure to keep the device you paired the Emberton III with close to the speaker to prevent this.
0 Comments
