Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
DVD Player will not turn on
No matter what you do, you can't get your DVD player to turn on.
Make Sure the Device is Plugged in.
If the device will not turn on, unplug from the wall then plug the chord back in.
Tray will not open
Check the chord to make sure device is turned on.
Press the power button.
Press the open/close button firmly.
Frozen screen
Turn Device off then back on.
Skip to next scene to make sure DVD works properly.
Make sure DVD is spinning. You should be able to hear it.
DVD in the tray has stopped working
Remove DVD from the device.
Make sure the picture side is up.
Check the back of the DVD to make sure there are no scratches.
Rub with soft cloth to remove dust or smudges.
No sound or picture
Check if the TV is switched on.
Make sure the TV is on the correct input.
Check the video connection.
Check the audio/video cable connections to the TV.
Picture is distorted
Sometimes a small amount of picture distortion may appear. This is not a malfunction.
Connect the unit directly to the TV.
Not responding to remote control
Aim the remote control directly at the sensor on the front panel.
Reduce the distance to the unit.
Replace the batteries in the remote control.
Re-insert the batteries with their polarities (+/– signs) as indicated.
Buttons on device not responding
Unplug the AC cord from the wall outlet for 5-10 seconds.
Then plug device back in.
Guides
MAGNAVOX MDV2300 Motherboard Replacement
MAGNAVOX MDV2300 Power Cord Replacement
Author
with
Aaron Harding
1 Reputation
0 Guides authored
Penn State, Team 1-41, Kaschak Winter 2015 Member of Penn State, Team 1-41, Kaschak Winter 2015
PSU-KASCHAK-W15S1G41
4 Members
24 Guides authored
2 Comments
What if u have done everything on here because it is all pretty much common sense and it (no matter what DVD is put in) stops about 10-15 mins later & says DVD error? ??
Christina Eastburn - Reply Share
DVD player it spins and it stops
Cool Amine (Coolamine) - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 4,621
