Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer Will Not Power On
The laptop will not respond or show any sign of powering up.
Faulty Power Adapter
Make sure that the power adapter is plugged in and the charge light is on. If the light is not on and the adapter is plugged in, the adapter is faulty. Consider purchasing a replacement adapter.
Faulty Battery
Having a faulty battery will cause the computer to struggle on startup, or even not start up at all. If it powers up only when the adapter is plugged in, the battery is faulty and must be replaced.
Computer Overheats, Causing a Blue Screen
Your computer fails to start up and takes you to the blue error screen.
Dust in Fans or Vents
Having excessive dust stuck in your vents or fan can cause the computer to overheat. This can be cleaned by using canned air to gently blowing the dust out.
Thermal Paste has become Old or Dried Out
Thermal paste is used to prevent overheating issues to the processor and heat sink. Overheating due to thermal paste is caused by the lack of paste, or air in between the two components. Use this guide to fix this issue and apply new thermal paste onto the heat sink.
Computer Powers On, Screen Stays Black
You power the computer on and get no response, screen stays black.
Loose Cable
Having a cable become loose could cause your LCD screen to fail. Follow this to ensure the cable is securely seated.
Faulty Screen
If the backlight on the LCD screen has failed, you will not see any images. In order to fix this problem, the entire inverter board and the connected LCD cable will have to be replaced. Replace them using this guide.
Keyboard Keys Stick or Won’t Work
The keys on your keyboard continue to stick, or are not working.
Broken or Stuck Keys
If a key sticks in place, try removing it from the keyboard. Thoroughly clean the key area and check for other obstructions.
Faulty Keyboard
If the keyboard is failing to respond, you can replace it using this.
Computer Fails to Start and Beeps Continuously
Your computer turns on, and immediately starts to beeps and freezes on a black screen.
Memory Error
Improperly set RAM would cause repeating beeps on start up. Follow this to ensure they are seated correctly.
Faulty RAM
If you are experiencing crashes normally or during memory demanding tasks, this means you have faulty ram that needs to be replaced. It can cause the PC to fail on startup and continuously beep. Install new RAM using this guide.
Failing to Start Windows
After powering on, the operating system will not start up.
Hardware or Software Change
A recent hardware or software change could cause issues after installing windows. Try this guide to repair.
Malfunctioning Hard Drive
If you are having issues starting Windows, this could be for a couple reasons. If your hard drive is going bad, you will notice things like slow load times, files and folder names will be changed or scrambled, or the operating system will not load. Replace the hard drive using this.
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 36
All Time: 1,685
