Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Audio Only Playing on One Side
When your Logitech G Pro X Wired Headset isn’t producing any sound on one side, outdated or missing audio drivers could be the issue. Along with incorrect settings or hardware problems.
Outdated or Missing Audio Drivers
To update your Logitech G Pro X headset's audio drivers through Windows Device Manager, press Win + X and select Device Manager. Expand the Sound, video, and game controllers section, then right-click on your Logitech G Pro X headset (if listed) and choose Update driver. Select Search automatically for updated driver software, and Windows will search for the latest drivers and install them if available.
To download the latest audio drivers from Logitech’s official website, visit their support page and search for your headset model (G Pro X Wired). Download the latest audio drivers specific to your operating system (Windows), and install the downloaded drivers. After installation, check the driver version in Device Manager to ensure it’s recent and matches the version provided by Logitech.
Faulty Window Settings
Sometimes, Windows may not automatically set your Logitech G Pro X Wired Headset as the default audio device. To set it as the default device, click on the little speaker icon in the system tray (bottom right of your screen). If you see “Logitech G Pro X Wired” listed, right-click on it and choose Set as Default Device. If it’s not listed, proceed to the next step.
Access Sound Settings by right-clicking on the speaker icon again and selecting Open Sound settings. Under Output, choose “Logitech G Pro X Wired” as the default device. Adjust the volume slider if needed.
Test the audio output by playing some audio (e.g., music or a YouTube video) to verify if sound is now coming through your headset.
Headphone Jack Not Plugged in All The Way
Sometimes, your Logitech G Pro X Wired Headset may not produce any sound. This could be because the headphone jack is not fully inserted into the audio port. To troubleshoot this, start by checking the connection of your headset. Make sure the headphone jack is securely plugged into your computer or audio device. If you see “Logitech G Pro X Wired” listed in the sound settings, it means the headset is properly connected. If it’s not listed, you may need to plug the headphone jack in more securely.
Next, access your Sound Settings by right-clicking on the speaker icon in the system tray (bottom right of your screen) and selecting Open Sound settings. Under Output, choose “Logitech G Pro X Wired” as the default device. You may also need to adjust the volume slider if needed.
Finally, test the audio output by playing some audio, such as music or a YouTube video, to verify if sound is now coming through your headset. If the sound is still not working, the issue might be with the headphone jack itself or the audio port on your device.
Remember, these are just possible solutions. The actual cause might differ based on the specific circumstances. Always consult with a professional if you’re unsure. I hope this helps! Let me kno
The Mute Button Is Unresponsive
The mute button on your headset might be malfunctioning due to a couple of potential issues. It could be physically stuck or jammed, or the system might not be recognizing its input.
Jammed Mute button
Sometimes, you might find that the mute button on your Logitech G Pro X Wired Headset is unresponsive. This could be due to a physical issue with the mute button or a software issue. Start by checking the mute button on your headset, which is usually found on the ear cup. Ensure it’s not stuck or jammed. If it is, try to gently unjam it.
Faulty System Settings
Next, check the system settings. You can do this by clicking on the little speaker icon in the system tray (bottom right of your screen). Select Open Sound settings and under Output, ensure that “Logitech G Pro X Wired” is selected as the default device. Check if the mute option is activated in the system settings.
You can then test the mute function by playing some audio, such as music or a YouTube video, and toggling the mute button to verify if it’s working properly. If the mute button is still unresponsive, you may need to uninstall and reinstall the Logitech G Hub software. To do this, press the Windows key, then type Logitech G Hub. Right-click the program and click Uninstall. After uninstalling, reinstall the program through the provided link: Logitech G Hub Download. ''''
Microphone Not Picking Up Your Voice
Logitech G Pro X Wired Headset’s microphone is not picking up any audio or audio cuts in and out throughout use.
Damaged cable
Inspect the cable diligently for fraying, kinks, or other signs of wear, if you find any damage, consider replacing the cable.
Improper connections
Unplug the auxiliary microphone connection from the headset then inspect the connector for any damage then reconnect it securely.
Dirty Ports
Ensure that the auxiliary port on the Logitech G Pro X Wired Headset is free from obstructions or loose components.
Visually inspect the auxiliary port with cable removed. Remove any debris or obstructions are in or on either port and ensure there is a snug fit when connecting the auxiliary microphone.
Outdated Software and Settings
Check for Updates on Logitech G Hub Software by visiting the Logitech G Hub download page. Download and install the latest version of Logitech G Hub and check for any firmware or software updates related to your headset. If there are any updates available, try updating the device.
Verify Your Computer’s Audio Configuration by right-clicking on the speaker icon in the system tray (bottom right of your screen). Then select Open Sound settings, Under Input, ensure that “Logitech G Pro X Wired” is selected as the default microphone. Check the microphone permissions and ensure it’s not muted.
Headphones Will Not Turn on
Logitech G Pro X Wired Headset will not power on. This could be due to a power issue, a problem with the headset itself or software settings.
Power Button Engagement is Faulty
Access your device's audio settings or control panel and ensure that the microphone is not muted in the software settings. Look for any mute options and disable them if necessary. Open an application or software that utilizes the microphone (e.g., voice recorder, video conferencing app) and attempt to record or transmit audio. If the microphone is still muted, proceed to the next step. Sometimes, a simple restart of your device or the application using the microphone can resolve mute issues. Close the application or restart your device and test the microphone again. Visit the manufacturer's website or software application for any available firmware updates for your device. Install any updates as recommended, as they may address mute-related issues.
Headphones are turned off in the software settings.
Access your device’s audio settings or control panel and ensure that the headphones are not turned off in the software settings. Look for any power options and enable them if necessary. Open an application or software that utilizes the headphones (e.g., music player, video streaming app) and attempt to play audio. If the headphones are still not turning on, proceed to the next step. Sometimes, a simple restart of your device or the application using the headphones can resolve power issues. Close the application or restart your device and test the headphones again. Visit the manufacturer’s website or software application for any available firmware updates for your device. Install any updates as recommended, as they may address power-related issues.
EarCups Falling Off
When the ear cups begin to deteriorate due to wear and tear or accidental damage,.
Damaged EarCups
The ear cups display visible signs of detachment, noticeable through their loosened fit. Furthermore, there's a discernible degradation in the sound stage, indicating a decline in audio performance. This decline can stem from a myriad of factors, ranging from regular wear and tear to accidental damage. However, with proper care and attention, these issues can be remedied by replacing the ear cups with precision and care. Engaging in this replacement process ensures the restoration of both the structural integrity and audio quality of the headset, thereby prolonging its usability and enjoyment for the user.
How to replace damaged ear cups
To replace the ear cups on your Logitech G Pro X wired headset, start by assessing the condition of the current ear cups for signs of wear, tear, or damage. Next, gently grasp the edge of one ear cup and pull it away from the headset, gently trying to wiggle the fabric out of the seam, a small intrunment can be used repeating the process for the other side if needed. Once removed, take a moment to clean the area around the ear cup mounts with a clean cloth or wipes to ensure a clean surface for the new ear cups. Align the replacement ear cups with the mounting points on the headset, pressing firmly around the edges until fabric is securely wedged into place with the assistance from small intstrument. Test the headset to ensure the new ear cups are properly installed, providing optimal comfort and sound quality. Regularly inspect the ear cups for signs of wear and tear, and replace them as needed to maintain peak performance.
Device Is not Available for Selection On Computer
The device might not be appearing in your computer’s settings, which could suggest that your computer isn’t recognizing the device.
Faulty Usb Connection
Look for the USB connector on your device, usually located on the headset cable. Verify if there are any visual cues indicating connection status. If the USB connector is not engaged (indicating the headphones are not connected), gently insert the USB connector into a USB port on your computer. Ensure the connector fits securely and is not loose. Examine the USB connector and port for any physical obstructions or debris that may be preventing a proper connection. Clear away any dust, dirt, or debris that could be obstructing the connection.
The Computer Is Not Recognizing the Headset.
Access your computer’s Device Manager by pressing Win + X and selecting Device Manager. Under Sound, video, and game controllers, look for “Logitech G Pro X Wired”. If it’s not listed, your computer might not be recognizing the device. Try unplugging and replugging the headset, or try a different USB port.
If the headphones are still not recognized, you may need to update your audio drivers. You can do this through Windows Device Manager or by downloading the latest audio drivers from Logitech’s official website.
Remember, these are just possible solutions. The actual cause might differ based on the specific circumstances. Always consult with a professional if you’re unsure. I hope this helps! Let me know if you have any other questions.
Author
with
Mrubbo
101 Reputation
0 Guides authored
1 Comment
there is no Balance option on the Headset Pro X.
Dakota - Reply Share
Past 24 Hours: 23
Past 7 Days: 203
Past 30 Days: 817
All Time: 26,845
