Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Mouse Randomly Disconnects And Then Reconnects
I want to use the G400s but sometimes Windows indicates my mouse has disconnected and then quickly reconnected
Replace The Cable
The cable may have loosened within the internals of the mouse. This causes certain motions to pull on the cable resulting in a short disconnect until the cable is no longer under tension, at which point it will reconnect to the computer.
Mouse Sometimes Stops Tracking
I want to use the G400s but the cursor stops moving on my computer screen
Dirty Sensor
The sensor may be covered with grime. Try gently cleaning it with a micro-fiber cloth.
Mouse Does Not Slide Properly
Sometimes my mouse sticks or does not travel smoothly over the surface it is on
Replace the Mouse Feet
The pads on the bottom of the mouse have worn down over time.
Sticky Buttons
One or more of the buttons on my mouse takes longer than normal to return to its normal position
Dirt/Grime Accumulation On The Side Buttons
You will need to disassemble the G400s according the disassembly guide and then remove the dirt under the problematic buttons.
Dirt/Grime Accumulation On The Main Right/Left Mouse Buttons
USB Is Damaged
My USB does not fit in the USB hub or is damaged
USB has dust or other material hindering use
If there is dirt or dust in the USB try removing it with a micro-fiber cloth. If that does not work it will need to be replaced according to the G400s Wire Replacement Guide.
USB has physical damage
The entire cable will need to be replaced according to the G400s Wire Replacement Guide.
Author
with
Max Evans
433 Reputation
3 Guides authored
USF Tampa, Team 16-7, Eyestone Fall 2016 Member of USF Tampa, Team 16-7, Eyestone Fall 2016
USFT-EYESTONE-F16S16G7
1 Member
36 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 38
All Time: 1,912
