Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Loose Steering Wheel
The wheel turns by itself or the wheel has no force against the turn.
Wheel Motor
Change your in game force feedback setting to change the feel of the wheel. If your in game settings did not change then your motor may have died and will need to be replaced. To do this follow our guide on replacing the motors.
Horn Stuck
The horn never ends or does not work.
Faulty Spring
If your horn button is unresponsive or is randomly going off, this could mean you have a bad spring in the horn button or the spring has left its mount. This means that you will have to open your device and replace the spring.
Vibration Motors
The wheel stopped vibrating.
Faulty Wiring
If your wheel has been dropped or is in poor condition the wiring inside may have been knocked out of place. This may require you to open the device and reconnect the wiring or replace it entirely.
Faulty Buttons
Buttons are unresponsive or get stuck in place when pressed.
Buttons are Sticking
When using the controller, the buttons stay stuck down or the buttons might feel “soft”. This may be due to the build up of dirt. In order to fix this, you need to clean around the buttons using rubbing alcohol between the crevices works as well take a q-tip and rub the side of the button, let it seep a little, and let it dry for while.
2 Comments
Horn flashing light is blinking from the begining and playstation does not recognise the wheel and nor buttons work
Josemi Pachón - Reply Share
Y si tiene fuerza pero se queda fijo a un lado, El force feed.bAck?
Alvaro VITO - Reply Share
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 65
All Time: 3,841
