Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
SCREEN TOO DARK
The visual display on the Lenovo Yoga Tablet 2 is not bright enough for easy viewing.
Auto brightness may be inappropriate for your viewing needs
From the home screen, swipe down from the top of the screen to open the quick settings menu. Check if the auto brightness setting is activated. Depending on your environment, this feature may be turned on or off for better viewing.
Brightness slider may be too low
From the home screen, swipe down from the top of the screen to open the quick settings menu. Increase the brightness slider by sliding it to the right. Make sure that the auto-brightness setting is off.
FAILS TO CHARGE/TURN ON
Your Lenovo Yoga Tablet 2 does not charge or fails to power up.
The correct charging cable is not being used
Check that you are only using a micro-USB charging cable connected to an AC power adapter for wall outlet charging. This will ensure the strongest charging connection. Using a different cable or plugging into a computer or power bank may prove sub-optimal for charging.
Internal battery may be dead
If your Lenovo Yoga Tablet 2 fails to charge at all and the charging indicator light (on the power button) does not come one, it is likely that your internal battery needs to be replaced. The part you need is a Lenovo L14D3K31 3.7V 9600mAh lithium-ion battery.
LINK TO BATTERY REPLACEMENT GUIDE
WEAK WIRELESS CONNECTION
The Lenovo Yoga Tablet 2 indicates a low wireless connection and fails to perform actions requiring the internet.
The device is not in range of a wireless network
If experiencing a weak wireless connection, make sure the distance between the wireless modem and the tablet is not too great. If within range but still experiencing a problem, disconnect and reconnect to the wireless modem on the tablet.
The wireless modem is malfunctioning
Wireless signal may be weak due to the modem. To reset the modem, turn it off for 10 seconds or use the reset switch on the back if one exists.
The wireless antenna is malfunctioning
You may have a faulty antenna within the device. You will need to replace the hardware within the device.
LINK TO ANTENNA REPLACEMENT GUIDE
FROZEN OR UNRESPONSIVE SCREEN
The screen on the Lenovo Yoga Tablet 2 is not responding to user inputs.
The operating system has crashed
If your Android OS crashes and you are unable to use the home button or enter settings through the use of the drop down notification menu, hold down the power for 10 seconds until the device restarts.
The application being used has caused an unresponsive screen
If your tablet freezes within an application and the system interface is still responsive, you can exit the app by use of the home button and close the problematic application using the recents menu.
The display is malfunctioning
You may have a faulty display. You will need to replace the display.
LINK TO DISPLAY REPLACEMENT GUIDE
DISTORTED AUDIO OUTPUT
Audio not coming from tablet or audio distorted.
Speakers are not working
Your speakers may be faulty. In this case you will need to replace the speakers in your device.
LINK TO SPEAKER REPLACEMENT GUIDE
Headphones are not working
Your headphones may be faulty. In this case, you will need to buy new headphones.
Headphones are not properly plugged in
Your headphones are plugged in but sound is not coming through them or not coming out properly. If sounds are only partially coming through your headphones or not coming through at all your headphones may not be properly plugged in completely. Ensure that headphones are properly plugged in.
TABLET OVERHEATING
Tablet overheats during general use, charging or while not in use.
Too many actions at once
You may be overworking your tablet. If you are using your tablet in a cool, dry environment and you are not charging your tablet while in use then your tablet should not be overheating. If it is overheating in these situations you may be doing too many things at once. Try closing some Internet tabs and closing apps not in use.
Tablet in hot environment
Your tablet may be in an environment that is too hot. Electronics are meant to be used in cool, dry environments. If you are not doing too many things on your tablet at once and you are not charging your tablet while in use than you might need to use your tablet in a cooler location.
Using charger while in use
You are using the charger while the tablet is in use. It is not recommended that you use your tablet while you are charging it. Aside from making it take longer for your tablet to charge, and possibly degrading your battery, your tablet may overheat if you use it while it is charging. Try letting your tablet charge while not in use.
Vernicia Gage
71 Reputation
0 Guides authored
USF Tampa, Team S2-G4, Nance Fall 2017 Member of USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Members
72 Guides authored
2 Comments
My tablet was charging overnight as usual,this morning it is humming,blinking as if charging but not connected to charger,will not start,and just sits there humming.any ideas?
agiuszelenkadec - Reply Share
Can you help me with the above problem?
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 44
All Time: 3,685
