Student In Progress
This wiki is being worked on by hardworking students.
Lenovo Thinkpad x13 Gen 1 Overheating
Under regular use, your ThinkPad x13 gen 1 is becoming abnormally hot. Follow this guide in order to diagnose and solve this issue.
Broken Fan
A broken fan on a laptop can cause significant thermal issues. These symptoms appear as: the device operating slowly, hardware instability, lack of noise coming from the fan, and the laptop eventually shutting itself down. This can be solved by replacing the fan on the cooler. Once you take off the bottom cover of the ThinkPad, you will find the fan located in the top left of the pc.
Thermal paste dried out
Dried thermal paste is a far less obvious issue that arises when a laptop is overheating. Symptoms of dried thermal paste can include high temps even with the fan running at full speed, the device operating slowly, hardware instability, and also a forced shutdown. This issue can be fixed by removing the heatsink and applying new thermal paste to the CPU-die.
Battery charging incorrectly (unbalanced cells)
Unbalanced cells in a laptop battery can become a major issue and can potentially see the battery eventually bursting into flames. Signs of a defective battery can include a failure to charge to 100%, the battery pack visually bulging, and reduced battery life. This issue would require the battery be replaced
Lack of airflow
When a computer suffers from a lack of air flow it quickly begins to overheat, leading to performance drops, system instability,and potential hardware damage. The central processing unit (CPU) generates a massive amount of heat that must be constantly pushed out of the chassis. There are a couple of ways to identify a lack of airflow including: excessive dust accumulated on the fan, an object physically blocking the exhaust, a potentially a broken fan. This would require either a cleaning or a fan replacement.
Background programs/software running
When a pc has too many programs running in the background, it dedicates more resources and consumes more power, causing the system to work harder and heat up. This problem can be identified by searching task manager in the search bar of the windows tab, and checking which program is using the most of your CPU and ram. Try closing out any programs or software's that aren't in use to help prevent this issue.
(DISCLAIMER: If you are unsure of what to uninstall, consult a professional)
Your computer uses up vital hardware resources and experiences several performance issues. Your CPU works harder on idle tasks , causing the cooling fan to run more frequently and loudly.
0 Comments
