Student In Progress
This wiki is being worked on by hardworking students.
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Lenovo ThinkPad T15 Gen 1 Touchpad Unresponsive
The Lenovo ThinkPad T15 Gen 1 touchpad does not respond when you move your finger across it or try to click or tap.
Touchpad Is Disabled
The touchpad may have accidentally been turned off through the laptop's settings.
  • Open Settings in Windows.
  • Go to Bluetooth & devices and select Touchpad.
  • Make sure the touchpad is turned on.
  • Move your finger across the touchpad and test the clicking function.
If the touchpad starts working again, no replacement is necessary.
Touchpad Driver Problem
The touchpad uses software drivers to communicate with the computer. If the driver is outdated, missing, or corrupted, the touchpad may stop responding.
  • Open Device Manager.
  • Look for the touchpad under Human Interface Devices.
  • Check for a warning symbol or error.
  • Update or reinstall the touchpad driver.
  • Restart the laptop and test the touchpad again.
If the touchpad works after reinstalling or updating the driver, the problem was propably caused by the driver.
Frozen System
A temporary software problem can cause the touchpad to stop responding.
  • Save your work if possible.
  • Restart the ThinkPad.
  • Once the laptop boots into Windows again, move your finger across the touchpad.
  • Test both the touchpad movement and clicking.
If the touchpad works after restarting but becomes unresponsive again, there may be a continuing software or driver problem.
Loose Touchpad Connection
If the touchpad is enabled and the driver is working correctly, the internal connection may be loose.
  • Turn off the ThinkPad and disconnect the charger.
  • Open the bottom cover.
  • Locate the touchpad and its connecting cable.
  • Check that the connection is secure.
  • Look for any visible damage to the cable.
  • Reconnect the cable if it is loose.
  • Reassemble the laptop and test the touchpad.
Damaged Touchpad
If the touchpad still does not respond after checking the settings, driver, and connection, the touchpad itself may be damaged.
Physical damage or a failed touchpad can prevent it from detecting movement or clicks.
  • Inspect the touchpad for visible damage.
  • Check that the internal connection is secure.
  • If the connection is working correctly but the touchpad remains unresponsive, replace the touchpad.
  • Test the replacement touchpad after installation.
Perform a Motherboard Hard Reset (Static Discharge)
Sometimes, residual static electricity on the motherboard can freeze specific hardware controllers. Shut down the laptop completely and disconnect the charger.
  • If you already have the bottom cover off, disconnect the internal battery cable.
  • Press and hold the power button down for 60 seconds to drain all residual power from the motherboard capacitors.
  • Reconnect the battery, close the case, plug in the charger, and turn the laptop back on.
Test in a Non-Windows Environment (Isolate Software)
To 100% rule out a Windows or driver corruption issue, test the touchpad outside of your operating system:
  • Boot into BIOS/UEFI: Restart the laptop and tap F1 repeatedly at the Lenovo logo. Once inside the BIOS menu, try moving your finger on the touchpad to see if the cursor moves.
  • Boot into a Linux Live USB: Create a bootable Ubuntu USB drive and run it in "Try Ubuntu" mode.
Diagnostic Results:
  • If it works in BIOS/Linux: The issue is strictly a Windows registry, controller, or software conflict. A clean reinstallation of Windows will fix it.
  • If it fails in BIOS/Linux: The issue is hardware. Since you already replaced the physical touchpad and checked the cable, the failure lies in the motherboard's tracking controller chip or a blown resistor inline with the touchpad connector.
Internal Hardware Failure
If the touchpad still does not work after replacing it, another internal component could be causing the problem. At this point, the laptop may need additional testing to determine whether the problem is coming from another component or the motherboard.
Aayat Kaiser Kawosa
101 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 53
All Time: 90
