Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Lenovo N23 Won’t turn on
Faulty Power Adapter
The power adapter is responsible for charging the battery inside your computer, if this is not working correctly it could be the reason the Chromebook won’t turn on. The easiest way to test this is to use a friend’s power adapter on your own computer.
Faulty Battery
If not the power adapter, the battery itself could be and could also be the problem. The battery is what actually holds the charge on the computer. If it is not working correctly the computer will not turn on while unplugged from the power adapter.
Faulty Charge Port
The charge port itself could also be the problem.
Faulty Motherboard
The motherboard allows all the different pieces of the computer to communicate with each other. If the motherboard isn’t working correctly parts of the computer may not be receiving signals from the motherboard, making the computer not turn on.
Screen Tearing/Flickering
Broken LCDs
LCDs or Liquid Crystal Displays are what your screen is made up of to create an image on your screen. If you are having certain sections of your screen “tear” it is very possible that some of your LCDs are broken and need to be replaced.
Insufficient/Bad RAM
Another possibility is that you have insufficient or faulty RAM. RAM is essentially the short-term memory of the computer. If your RAM is not working correctly it could cause the screen to tear.
Unstable Wireless Connection
Bad Wi-Fi Stability
Your computer may be unable to connect to the Wi-Fi if it is not stable. Try resetting your Wi-Fi then attempt to reconnect.
Faulty Wi-Fi Card
The Wi-Fi card is responsible for connecting the computer to the user’s Wi-Fi, if it is not working properly then you will be unable to connect to the Wi-Fi.
Trackpad does not function correctly
Unresponsive Operating System
An unresponsive operating system is what causes the computer to freeze. When the system is unresponsive, the input commands are not received, suspending all current actions until the connection is re-established.
Fn Key Combination
It is possible for laptops to have a Fn key sequence that allows the enabling and disabling of the trackpad. Sometimes this sequence may be pressed by mistake, turning off use of the trackpad.
USB Accessories
USB accessories consist of devices such as mice, microphones, headphones, or data drives. When these are plugged into any of the USB ports, some - such as mice - may disable use of the trackpad until they are removed.
No Screen Response
Broken LCDs
If parts of or your whole screen are unresponsive, the LCDs of your screen could be broken and would need to be replaced.
Faulty RAM
RAM allows your computer to do multiple or strenuous tasks at the same time. If your RAM is not working properly it may cause your screen to be unresponsive.
Broken Motherboard
The motherboard allows all parts of the computer to interact with each other, if the motherboard is broken your screen may be unresponsive.
Author
with
Austin Blakely
23,463 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Comment
I have a question, my Lenovo N23 chrome book cannot use Bluetooth or the USB ports, is it related to the motherboard or the parts themselves?
Joe - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,402
